Originally Posted by hestersu
Interesting that they would use non OEM parts. We have another user on the org that swears California requires all new OEM parts when repairing cars. Check with the State Board of Insurance to make sure that Farmer's is following the law and check your rights under your policy.
The bumper cover (fascia) is plastic. I wouldn't use a re manufactured part for the cover. At some point, what ever has been repaired will eventually show up. The fascia is around $250 or so new. You might look into buying the part yourself or chipping in to get the proper part. The OEM part comes pre primed and will take paint a lot better than some re manufactured part.
Calif has no law requiring use of OEM parts....some insurance carriers use nothing but OEM parts, some will allow you to purchase extra coverage that will pay for OEM only parts, others have a policy of using OEM parts in the first 2-3 years of age of the vehicle, while others have no particular claims policy for the use of OEM/non-OEM parts. Non-OEM parts are made to OEM specs though, but are made by companies that don't supply their parts directly to auto manufacturers. Quality of fit is usually the culprit of the dislike of non-OEM body parts. The use of re-conditioned bumpers and wheels is quite common. What is commonly behind the bumper is styrofoam or a styrofoam-like material that flexes in minor collisions covered by the usual vinyl cover that is typically either the body color or black. As with wheels, there is a company that rehabs wheels with aesthetic issues, such as scratches in the finish that are structurally sound and made to look brand new. In the end, if the non-OEM part doesn't fit properly, then a good insurance company will pay for the OEM part. As with windshields, the cheap Chinese made windshields may meet minimun DOT requirement, but they typically have optical quality issues as compared with companies that make OEM windshields such as PPG or Carlite. The use of reconditioned parts is no different than using remanufactured starters, alternators, and racks. The auto insurance policy is not one of replacement value (new for old), but one of "actual cash value", so depreciation is also commonly taken on wear and tear parts, such as tires, upholstery, electronics, and paint. In the case of Farmer's use of "preferred body shop network", this, too is a common practice, though in Calif it is against the law to require use of a particular body shop or the gathering of estimates. The claimant is allowed to choose the bodyshop of his/her choice. "Preferred" shops are usually given extra latitude if they find hidden damage to initiate repairs with just providing documentation, the insurance carrier usually warranties the work done at that shop for as long as the person own s the car, and also can act as an advocate of the claimant in case of a problem in the work after completion. If the person chooses their own shop (not the carrier's preferred shop) and has a problem with the shop's quality afterwards, they are on their own, since they chose that shop.
