Touch up paint? - NewBeetle.org Forums
Old 02-15-2009, 06:04 AM
PinkBug4289's Avatar
St.Louis, MO, USA
Car: 2004 Turbo S
Exclamation Touch up paint?
I have purchased the tiny bottle from an auto paint store to touch up dings on my beetle.
My question is if they make some spray paint that matches your car color that you can paint over LARGER areas to cover scratches? Can you not do that without painting the entire car? Any help?
Could you buy the color of you car(In my case black) and then buy an enamel top coat?I'm looking for a semi-easy fix without using and air compressor etc to paint it like the pros do it.
Old 02-15-2009, 12:44 PM
CGK's Avatar
Beetleman
Salisbury, NC, USA
Here ya go: http://www.paintscratch.com/
Perfect match for your paint and be sure to prepare the area
properly. 99% of any touch up job looking good is in the preparation.
Good Luck
Old 02-21-2009, 04:57 PM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Default Try your dealer parts dept.
I've been able to buy small spray cans from my local VW dealer parts department. I believe it was about $17 and comes with a can of clearcoat varnish. I've used mine for painting steering wheel spokes, the rear tow hook cover, and door grabs. While the cans are small, they are a perfect match for the car! Check out my DIY for painting stuff in my Sig.
SoCalnewbeetleclub
has anyone ever used the spray can touch up paint mrsbeazley Paint and Body 3 06-10-2008 02:15 PM
Touch up paint and scratches... efesese New Beetle Detailing/Cleaning 9 08-19-2007 11:06 PM
Touch up paint BeccyBug Paint and Body 2 07-29-2006 03:43 PM
Touch Up Paint ghostRder1 Paint and Body 7 05-25-2006 09:06 PM
Touch up paint, any suggestions Breez Paint and Body 25 04-19-2006 09:30 PM
