Need advice on fixing a dent - NewBeetle.org Forums
Old 01-06-2006, 02:21 AM
usmcrettop's Avatar
MoPic Rules
Fairfax County, Centreville, Virginia, USA
Car: 2001 GL (homemade Wolfsburg edition)
Default Need advice on fixing a dent
Hi,
I have a small dent in the rounded body panel just below the passenger door. It's the area you would call the running board on the old air cooled bugs. About half of this panel has been slightly flatten. Does anyone out there in "beetle-land" have experience fixing these? Looking for any advice . . .
(PS-does anyone have any info on a running board conversion kit for the new beetles??)
Thanks for your time and all the best, Jerre
"The brave ones were shooting the enemy, the crazy ones were shooting film."
Norman Hatch,
USMC WWII Combat Photographer
Old 01-06-2006, 02:31 AM
I'd go with running board covers, they're black rubber and look good enough.
I'd fill the area with bondo or something before applying the kit though, or else the rubber will probably warp into the void.
TMTuning.com carries the kit, not sure about other places.
As a purist, I have to call shame on you for the 'homemade wolfsburg edition' Beetle, but that's just my opinion and it's your car.
Good luck dude!
SMG
Old 01-06-2006, 02:33 AM
Just to add, in case you don't want to do covers:
These running boards aren't swappable like most parts, they have to be cut out and new ones welded back in.
Old 01-06-2006, 03:12 AM
usmcrettop's Avatar
MoPic Rules
Default Thanx for the quick response
Figured it wasn't an easy part to get to, remove or replace. Think I'll have a look at your suggestion, thanks again, Jerre
Old 01-06-2006, 03:34 AM
silverspoiler's Avatar
Halifax, Nova Scotia, Canada
Car: 2001 New Beetle GLS
That part is called the rocker panel.
I had to fix the same part a few year ago after it was dented in a similar manner. I had it done by a bodyshop, and it wasn't terribly expensive. I was told that the entire rockerpanel had to be replaced, you can't just cut out the damaged part of it.
I don't remember the exact figure, but I don't think it was anymore than $400 (Cdn). Now there is no evidence left.
Good luck.
Old 01-06-2006, 03:38 AM
usmcrettop's Avatar
MoPic Rules
Default Rubber Running Board Covers
Any additional suggestions on where I might find Rubber Running Board Covers, kinda' like the idea and it would go nicely with my "old school" hubcaps . . .
Travel Advice madjalapeno Miscellaneous Hoo-Ha Archive 10 12-10-2005 03:50 PM
Need Audio Advice lebicicletta Car Audio 8 10-31-2005 09:57 PM
Hood Dent - How to fix? crazi_daisy Paint and Body 4 10-29-2005 02:43 AM
Need some advice on where to buy accessories... au01st Styling Modifications 21 09-29-2005 08:30 PM
