Cabrio hood lubrification help needed ... - NewBeetle.org Forums
Old 01-24-2010, 06:03 PM
Mafra, Lisboa, Portugal
Car: 04 New Beetle Cabrio Tdi
Default Cabrio hood lubrification help needed ...
Hello, i`m new to the forum and i`m in Portugal, just recently bought a 2004 New Beetle Cabrio TDI 100HP and everyone tells me i should periodically lubrificate the hood components but i really don`t know where to start, can someone please give me a hint on how to do it and what parts to lubrificate and what is the best product to do it??? Thank a lot.
If someone knows some video about this issue please let me know.
Old 01-25-2010, 01:10 AM
palmdale, CA, USA
Car: 2000 18T
Im not aware of any points on the hood that need lubrication, but if there referring to the hood struts, hinges, & hood lock assembly. then sure lube them it couldn't hurt. I would probably get some pneumatic lube or hydraulic fluid and wipe the exposed metal of the strut with a rag just give it a light coat on the rag and wipe. as far as the hinges and lock assembly I would use royal purple maxi film Royal Purple Protect Parts once again but you spray this stuff on and make sure to use a rag or two and keep it from spraying every where and then wipe the excess fluid off the hinges and lock assembly. reason for wiping is to keep it from getting everywhere and it helps to keep the dirt down and off of it. just do this regularly and you should have the sweetest hinges, lock assembly, and struts in town.
snortingrooster
P.S if you cant find royal purple any other lubricating lube should work. you could use grease for the hinges and lock assembly but I would use the lube since the parts are still attached to the car. grease them if you ever remove them to rebuild it.
Old 01-30-2010, 04:34 PM
Wink
snortingrooster
Thanks
Tow bar on cabrio Bird New Beetle Convertible 0 08-24-2009 10:38 PM
Local NB Cabrio (Black) Needed For Movie Shoot In Chicago BUGSTUFF USA: Midwest 0 04-26-2009 11:40 PM
04 1.8T Cabrio PGTBrow Photos: New Beetles 9 04-22-2009 02:18 AM
Will wheels from a MK3 Cabrio fit the NBeetle ? Mr Natural Styling Modifications 8 08-22-2006 06:54 PM
Cabrio hood cleaning! Lisa Questions, Issues, Concerns, or Problems with the New Beetle 3 10-09-2005 06:32 PM
