I recently bought a set of Smoke colored Turn Signal Repeaters to replace the clear ones....
Well, as suggested in the Haynes repair manual, to remove the marker, you have to pry the light off by pushing it slightly in since it has a release clip... well I taped the area off and did just that just to have the clear lens fall off...seems broken and I can't figure out for the life of me how to remove the rest of the piece. The marker still is plugged in and works but the lens part is cleanly broken off....and to make matters worse, the new smoke versions don't look like they will fit the hole....damn...now what?!?!?! ANYONE please help me!!!! Thanks in advance. ![]() ![]() |
I'd get a set of fine-nosed needle-nosed pliers and gently get a grip on the back-half of the piece that is just sort of rattling around in there now, and you should be able to just pull it out.
Bumbls : 2011 Ford Transit Connect XLT
Sting : 2002 1.8T Beetle Color Concept My FLICKR: See My High-Res Photos Here Cameras I Use: Canon Eos 40D |
Hey I've tried to pull it out and it's no use...the nose needle pliers just erroded the white housing of the repeater leftover...
I SERIOUSLY NEED HELP!!! If anyone out there has had to replace or remove these repeaters, can you please post your experience? Thanks in advance. ~Maggie |
| P/s turn signal | etsmarch05 | 1.8 Liter Turbo | 0 | 07-01-2009 05:57 PM |
| Turn signal | 4toyhln | 1.9 Liter TDI | 2 | 10-04-2008 04:53 PM |
| turn signal flasher | beetlejuice | Questions, Issues, Concerns, or Problems with the New Beetle | 10 | 04-27-2008 12:07 AM |
| Crazy Turn signal | gerryh | 1.8 Liter Turbo | 4 | 02-06-2007 10:13 PM |
| Turn signal question | Mr.Yellow | Styling Modifications | 5 | 09-29-2006 12:04 PM |
