Fixing surprises - NewBeetle.org Forums
Old 08-21-2010, 09:40 PM
SUPER M's Avatar
crazy bones
Swamp land La,
Thumbs up Fixing surprises
In a nine year old car ?
When you pull a panel and find a broken tab or bracket what do you do ?
Throw it away and buy a new one ( That can get expensive ) or repair the one you have
This is what i do......
The panel after all the gook has been removed .
a close up of the broken tabs.
Old 08-21-2010, 09:52 PM
SUPER M's Avatar
crazy bones
Swamp land La,
This is the little bracket thats being repaired.
plastic welding works well if you know your plastic the panels in most cars is ABS so you have to use the right type to make it work.
these are the tools i use for the repair.
You start by melting the brake and make a little V grove at the joint to place the filler for the weld.
This is the filler rod.
After the tab is welded in file the weld down to smooth it out.
and just like new...
Old 08-21-2010, 09:57 PM
SUPER M's Avatar
crazy bones
Swamp land La,
The corner of this bracket was broken ....
fitted the broken piece....
And the welding ...
After filing time for paint ...
Old 08-21-2010, 10:02 PM
SUPER M's Avatar
crazy bones
Swamp land La,
Pics of the painted panel soon.
Thanks for looking
Questions comments are welcomed....
fixing a seat latch lamberse Questions, Issues, Concerns, or Problems with the New Beetle 4 06-24-2009 11:43 PM
worth fixing? warren Photography 2 04-25-2006 11:32 PM
Fixing a scratch on my 2006 NB Geed Paint and Body 3 03-10-2006 08:51 PM
Need advice on fixing a dent usmcrettop Paint and Body 5 01-06-2006 03:38 AM
