Help! Removing Door Mirror Trim? - NewBeetle.org Forums
Old 06-22-2011, 01:59 AM
Default Help! Removing Door Mirror Trim?
I tried to get this part off the door today and I couldn't figure it out for the life of me.
I found two clips on the front of the door and it was sort of coming but it looked like some kind of bracket in the middle of the piece was going to break off and I didn't want to ruin it. Does this have to come off with the door rubber or what? I couldn't find anything about this part in the Bentley manual.
Help?
Old 06-22-2011, 02:10 AM
Nevermind.. I figured it out I think.
Old 09-15-2011, 03:47 PM
Did you figure it out? I'm having the same issue, could you share your solution?
Old 09-15-2011, 04:24 PM
MyOtherRidesAVette's Avatar
Here you go, the exterior cover removal is different, based on your year, I have posted both.
This should be all you need. P/m me if you need something further
MORAV
In der Automobil-Scheune
Old 09-16-2011, 02:56 AM
You have to pull the window seal out and there's a Philips screw in there.
How To: Remove Window Trim (B-Pillar Door Trim) Darkstar Paint and Body 5 05-22-2012 05:10 PM
Removing B-Pillar Trim? SMG Paint and Body 4 06-03-2010 09:35 PM
Removing Headliner Trim dbreese Questions, Issues, Concerns, or Problems with the New Beetle 0 02-05-2009 06:18 PM
How to removing outside mirror joystick? AndrewC Questions, Issues, Concerns, or Problems with the New Beetle 4 06-24-2008 11:48 AM
Door Handle Loose/Removing Door Panel? kpierce Questions, Issues, Concerns, or Problems with the New Beetle 1 05-22-2008 02:43 AM
