FS: 1998-2005 LHD E-Code Headlights - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > Marketplace > Parts and Accessories
Parts and Accessories Your source for buying, selling, and trading parts and accessories. Commercial posting is allowed in this forum.
Old 02-06-2008, 05:48 PM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Arrow FS: 1998-2005 LHD E-Code Headlights
New-in-box Bosch e-code headlights, for 1998-2005 New Beetles. Comes with leveling motors, city lights, everything you need except bulbs and wiring for the leveling motors.
Also I'm including the leveling rheostat/dimmer switch, and the wiring harness connectors needed to make them work on non-Turbo S models. Turbo S is plug'n'play (as they have the 8-pin connector I believe).
SOLD!
-Des
Previously:
Old 02-06-2008, 08:18 PM
01turbo's Avatar
Cyber Green GLX 1.8t
Bensalem, PA, USA
Car: 01 GLX 1.8t ATX Cyber Green
those are TIGHT
2001 Cyber Green GLX Turbo
  • (2) 1st Gen 12" Kicker Solo Baric L7s, sealed
  • Kenwood Excelon KAC-X1R
  • Alpine 7833
  • 4 ga. Monster power
  • iPod to Alpine interface
  • TSUNAMI 10-Farad cap - coming soon
  • 4300K HIDs (Philips capsules/Hella ballasts)
Old 02-06-2008, 10:44 PM
vdubbugman53's Avatar
Arvada, CO, USA
are those HID?
Old 02-07-2008, 01:06 AM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
Originally Posted by vdubbugman53
are those HID?
Don't believe so. I think they're just standard e-codes. I could be wrong though.
LOOK AT MY Bug!!!!
Old 02-07-2008, 03:06 AM
Are those glass or plastic?
Old 02-07-2008, 07:30 AM
Deserion's Avatar
Moddin' Lion
Plastic, non-HID. Improved beam pattern versus NA-spec, could be a good basis for an HID retrofit (thanks to a sharper beam, less distortion and glare).
They need to go to a good home!
Old 02-12-2008, 06:39 AM
Deserion's Avatar
Moddin' Lion
Bump... now $480.
Old 02-23-2008, 02:37 PM
worbc's Avatar
Tustin, CA, USA
Default PM Sent
PM Sent -- Money sent!
--terry
-_-_-_-_-_-_-_-_-_-_-_-_
Terry (WORBC) Rector
1999.5 NB with following modifications, VR6 Clutch & Lightweight Flywheel, CARACTERE body kit, Special modified exhaust with Magnaflow Muffler, Three Gauge Pod with Boost, Oil & Water temp gauges, Rocketchip Stage III, Sprints 520s, ProSound System, ProVent CCV
"You can't build a reputation on what you're going to do." Henry Ford
E-code headlights KevinR Technical Modifications 13 02-01-2008 09:57 AM
1998 with a VAG Code P0172 Need Help bigdoe1014 2.0 Liter Gas 4 06-19-2007 06:31 AM
For Sale: Used Painted 1998-2005 VW Beetle Rear Spoiler vw_bug Market Place Archives 11 03-24-2006 05:18 PM
1958/1998 beetles in snow 2005 bsvwoc@msn.com Photos: Other Rides 12 01-02-2006 03:57 AM
1998 or 1999 Headlights Wanted Stinkbug Market Place Archives 0 12-08-2005 12:11 AM
