Cha2ga's Fusca Tdi - Page 3 - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Photos: New Beetles
  #41 (permalink)
Old 03-20-2015, 03:09 PM
cha2ga's Avatar
Liberty, SC,
Car: <a href="http://newbeetle.org/forums/photos-new-beetles/85170-cha2gas-fusca-tdi">00 Beetle Tdi</a>
Resealed my injection pump last weekend at Richard55's GTG in Covington GA. Set the timing almost perfectly in the center (53) and IQBAL at 3.6 with hammer mod. Last tank 49.5 mpg.Name:  ImageUploadedByAutoGuide1426864139.721579.jpg
  #42 (permalink)
Old 03-20-2015, 03:10 PM
cha2ga's Avatar
Liberty, SC,
Turned 177777 this morning on the way to work.Name:  ImageUploadedByAutoGuide1426864219.356327.jpg
  #43 (permalink)
Old 03-22-2015, 02:18 AM
cha2ga's Avatar
Liberty, SC,
Default Cha2ga's Fusca Tdi
Installed a Flowmaster 15369 exhaust tip. The turndown pipe was resonating after I removed the cat and muffler. This tip is 2.5" inlet and 3.5" dual outlets and was welded on. It helped reduce the resonance and has a deep throaty sound and can easily hear the turbo.
http://www.flowmastermufflers.com/?p...1&partno=15369
Size:  85.2 KBName:  ImageUploadedByAutoGuide1426990696.540071.jpg
  #44 (permalink)
Old 03-22-2015, 05:53 PM
cha2ga's Avatar
Liberty, SC,
Installed VW logo puddle lights. $15 on eBay. Looks like a decent kit. Name:  ImageUploadedByAutoGuide1427046577.578053.jpg
Size:  83.2 KBName:  ImageUploadedByAutoGuide1427046594.248481.jpg
Size:  84.7 KBName:  ImageUploadedByAutoGuide1427046609.039092.jpg
I removed the fuse for the interior lights. Drilled the hole with the provided hole saw. Splice the wires into the existing puddle lights and put everything back together. Did both doors in 45 minutes. I'll post more pictures after it gets dark tonight.Name:  ImageUploadedByAutoGuide1427046804.037500.jpg
Size:  257.9 KBName:  ImageUploadedByAutoGuide1427046821.929570.jpg
  #45 (permalink)
Old 03-25-2015, 11:26 PM
cha2ga's Avatar
Liberty, SC,
Size:  81.3 KBName:  ImageUploadedByAutoGuide1427325975.713266.jpg
  #46 (permalink)
Old 04-04-2015, 12:01 AM
TechnoTrix'd's Avatar
Everett Street in May
Brookhaven, PA, USA
Car: '01 NB TechnoBlue 1.8T GLX - Pepe Jr,
Garage
Came out great!
Hey Click ME! ToD-8 GTG & Cruise - - -ToD North East Bugavan Thread 2k16
Previously Owned Vdubs: '83 Blk GTI (Da' Bomb - moon-roof, ball shift knob, crazy striped interior), '87 Vanagon (Weekender - Brown), '90 Vanagon (Weekender - White, alloys, - one style'n refrigerator on wheels), '08 Graphite Blue Passat LUX.
  #47 (permalink)
Old 04-04-2015, 08:34 PM
cha2ga's Avatar
Liberty, SC,
Thanks!
  #48 (permalink)
Old 04-13-2015, 01:35 AM
cha2ga's Avatar
Liberty, SC,
Did my stealth race pipe and EGR cooler delete today. I used a spare EGR with a bad diaphragm and made a srp out of it. I removed the EGR cooler.
I used the one piece hose from idparts to the heater core. I used a 18" high pressure 3/8" hose and barb for the coolant return hose. I'll never have to do this again!
Size:  105.4 KBName:  ImageUploadedByAutoGuide1428888648.491231.jpg
Size:  118.0 KBName:  ImageUploadedByAutoGuide1428888660.646740.jpg
Nasty EGR!
This us everything that didn't go back in!
  #49 (permalink)
Old 04-13-2015, 01:43 AM
cha2ga's Avatar
Liberty, SC,
When I was taking everything out I found the gasket for the EGR small hose from the EGR cooler had not been installed by the last person who did this job! I bought the car with 146k and it now has 179,500. I always wondered where the smoke under the hood was coming from!
  #50 (permalink)
Old 04-14-2015, 01:31 AM
281superbeetleboy's Avatar
houston, TX, USA
Car: 2013 black conv,
Originally Posted by cha2ga View Post
love the lights.......
  #51 (permalink)
Old 04-16-2015, 10:11 PM
cha2ga's Avatar
Liberty, SC,
Thanks!
  #52 (permalink)
Old 04-16-2015, 10:14 PM
cha2ga's Avatar
Liberty, SC,
New nozzles from Andrew and Angelica at fixmyvw.com.
Bosio DLC1019!
  #53 (permalink)
Old 04-19-2015, 09:55 PM
cha2ga's Avatar
Liberty, SC,
I'm not very proud of myself at this moment. As a experienced Marine Corps helicopter mechanic and then receiving an industrial maintenance degree and working in industry as a maintenance and engineering technician for more than 20 years, all I can say is I screwed up. I was using a calibrated torque wrench. Unfortunately it doesn't help if the torque setting is the wrong one! I snapped off the bolt of the #2 injector hold down clamp inside of the head. I had the torque wrench set to 30ft-lbs. It never got close to 30ft-lbs, it was turning very easily but obviously snapped. I have sprayed Sili-Kroil into the top of the broken bolt and allowed it to sit. When I push on the sides of the bolt with a jewelers tip screwdriver, I can see the Kroil move around and the bolt looks like it is not tight in there, it appears to have some movement. I know I deserve the criticism; however, right now I would prefer your help. I'm thinking I need to use a left hand drill bit or an easy-out. Any help and suggestions to get me out of this bind are appreciated.
  #54 (permalink)
Old 04-20-2015, 11:21 PM
cha2ga's Avatar
Liberty, SC,
Bought left handed bits but before I tried the new left handed bits, I figured I would try to tap it out after 24 hours soaking in Kroil. My college freshman daughter patiently held the light for me. Took about 45 minutes. Slow. Patience is the key. I'm so thankful this worked out. Hopefully the new hardware will be at the dealer tomorrow!
  #55 (permalink)
Old 04-20-2015, 11:22 PM
cha2ga's Avatar
Liberty, SC,
Size:  101.8 KBName:  ImageUploadedByAutoGuide1429572127.718285.jpg
Size:  96.2 KBName:  ImageUploadedByAutoGuide1429572141.716558.jpg
  #56 (permalink)
Old 04-21-2015, 01:51 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Yeehaw! Great job! :-)
Sent from AutoGuide.com Free App
Got a trouble code? Look it up; on the Ross Tech Wiki!
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Need to find a VW part number? Look up here: http://parts.vw.com/
Then, use google; to find the best prices! :-)
  #57 (permalink)
Old 04-21-2015, 03:06 AM
cha2ga's Avatar
Liberty, SC,
Thanks Billy!
  #58 (permalink)
Old 04-22-2015, 03:14 AM
cha2ga's Avatar
Liberty, SC,
Installed Bosio DLC1019 nozzles Name:  ImageUploadedByAutoGuide1429672493.021448.jpg
  #59 (permalink)
Old 04-22-2015, 03:28 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
So, are these injectors a upgrade that works in conjunction; with a tuning upgrade or other performance parts?
  #60 (permalink)
Old 04-22-2015, 06:07 PM
cha2ga's Avatar
Liberty, SC,
20hp and 40lb-ft torque by themselves. Pretty good gain on a stock ALH tdi (90hp 155lb-ft). With a stage 3 tune it should go to about 150hp and 250lb-ft which replicates the European version of the engine. Can add a stock European VNT17 turbo and savage 4 for even more. The Pistons, rods, crank, etc can easily handle it because it's the same as the European engine. Very popular Tdi mod. Upgraded clutch may be needed (definitely with the turbo upgrade). Many, like myself, run a VR6-G60 clutch and pressure plate.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
TDI 101 - Important information for all TDI owners to know MichelleRoze 1.9 Liter TDI 21 05-24-2014 04:56 PM
02 tdi GTO2 New Member Forum 12 12-16-2011 03:53 AM
02 TDI Beetle TDI no start billybob69 1.9 Liter TDI 4 09-07-2011 04:19 PM
TDI or not to TDI, that is the question.... ohmab New Member Forum 9 05-29-2009 11:51 PM
