Cha2ga's Fusca Tdi - Page 7 - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Photos: New Beetles
  #121 (permalink)
Old 08-27-2016, 02:00 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Looks good, are you going to paint the new pod yellow; as well? I'm generally, not a fan; of the plastic texture/shiny surface; on the aftermarket plastics they sell. I would want, to keep the glare down; I wonder, if you converted it in a matte vinyl of some sort, maybe it would look good? A little bit of stitching; around the curves and it would look cool and 'factory' styling! The blue faces, on the gauges; sets it off nicely!
Got a trouble code? Look it up; on the Ross Tech Wiki!
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Need to find a VW part number? Look up here: http://parts.vw.com/
Then, use google; to find the best prices! :-)
  #122 (permalink)
Old 08-27-2016, 03:49 PM
cha2ga's Avatar
Liberty, SC,
Car: <a href="http://newbeetle.org/forums/photos-new-beetles/85170-cha2gas-fusca-tdi">00 Beetle Tdi</a>
I'm torn between going back to black or redoing the yellow.
  #123 (permalink)
Old 08-28-2016, 05:06 PM
Gringo's Avatar
NC, USA
Car: 2002 Turbo S, 1999 2.0 GLS
Garage
https://youtu.be/pAgnJDJN4VA
Have Bug, Will Travel
  #124 (permalink)
Old 10-16-2016, 04:01 AM
cha2ga's Avatar
Liberty, SC,
My radio reception was very poor. I replaced the antenna base when I first bought the car. I incorrectly used an aftermarket non amplified base and the signal improved only marginally.
I learned that the oem VW base has a circuit board with a sgnal amplifier built into the base. I bought one from fixmyvw and installed it. The signal has improved dramatically!
  #125 (permalink)
Old 10-31-2016, 03:05 AM
cha2ga's Avatar
Liberty, SC,
My trunk light has not worked for a long time. I replaced the trunk latch and it is working again.
  #126 (permalink)
Old 10-31-2016, 03:48 PM
TOD8 May 6-8 2016
Car: Cup- y2k Blk nB GLS 1.8t / Chino: 2013 Beetle 2.5
Garage
Sent from my SM-J700T using Tapatalk
CLICK-- Cup- my New Beetle Chino- my 2013 Beetle
  #127 (permalink)
Old 11-16-2016, 11:26 PM
cha2ga's Avatar
Liberty, SC,
Default Cha2ga's Fusca Tdi
204, 088 miles
Had a Check Engine Light come on. Used my VCDS to scan and it was:
16764 / P0380 code (Glow plug/heater circuit electrical fault
I used my fluke multimeter to check resistance of each glow plug: 10.5Ω, 1.8Ω,1.8Ω,1.8Ω. Obviously the first glow plug was bad. It's nice that with a diesel you only replace the bad one, unlike spark plugs, because they are not a wear item.
I ordered a new Bosch 80028/0250202022 Duraterm Glow Plug. I sprayed Sili-Kroil on the old plug and drove for a day. Set my Armstrong click torque wrench to 24ft-lb and attempted to loosen plug. This was to ensure that it would come out easily without over torquing of breaking it off in the head. It loosened easily and I removed it the rest of the way by hand and not with the socket. I applied Loctite copper antisieze to the threads of the new plug and hand threaded it without any tools to ensure it was not cross threaded. I titled to 11ft-lbs. reattached the harness. Scanned and cleared codes with VCDS. Too it for a drive and CEL did not come back. Rescanned and no codes were present. Since I already had the VCDS and tools and antisieze, the total damage was $12.38 with free shipping with Amazon Prime.
  #128 (permalink)
Old 11-16-2016, 11:55 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Another successful repair; good job! Just think, how much a VW dealership, would have charged for that repair? It is SO satisfying; doing your own repairs and getting oem parts, for cheap off the internet!
  #129 (permalink)
Old 11-17-2016, 02:14 AM
cha2ga's Avatar
Liberty, SC,
Thanks Billy! Next up is the rear axle bushings. I have the tool. Can't decide on which bushings to use, normal or Cupra
  #130 (permalink)
Old 12-11-2016, 05:53 PM
cha2ga's Avatar
Liberty, SC,
205,287 miles
Well the CEL for the glow plugs came back on. This time it was the #2 cylinder that was bad. Went ahead and ordered three new ones as above. All four glow plugs changed within last 1200 miles. Don't feel like chasing this all winter so I went ahead and did them all.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
TDI 101 - Important information for all TDI owners to know MichelleRoze 1.9 Liter TDI 21 05-24-2014 05:56 PM
02 tdi GTO2 New Member Forum 12 12-16-2011 04:53 AM
02 TDI Beetle TDI no start billybob69 1.9 Liter TDI 4 09-07-2011 05:19 PM
TDI or not to TDI, that is the question.... ohmab New Member Forum 9 05-30-2009 12:51 AM
