Trunk not staying closed? - NewBeetle.org Forums
Old 06-20-2006, 02:12 AM
chaddicus's Avatar
Volktron
Troy, AL, USA
Car: 03 Turbo S Volktron
Default Trunk not staying closed?
So my trunk isn't staying closed. I close it and lock the car and just a few moments later the alarm goes off? I turn the car on and notice that the trunk light is dim yet on. Anybody else have this issue? It's really annoying and thus I cannot lock my car otherwise the alarm will go off? Any suggestions, aside from the dealership. I'm not even sure if it'll be covered under the warranty. I have the certified pre owned warranty and I'm sure this falls under an electrical problem of some sorts?
Black 03 Turbo S. 35% Window tint, Silver Dash/Console kit, Black Tails, Clear Front/Rear markers, Phatnoise thanks to 1Coolbug, and sometimes I've got the Turbo S Bra on. look me up on myspace http://myspace.com/luckylock
Old 06-20-2006, 11:16 PM
Mine has done this maybe 2 times in the past 3 years. I never did anything to fix it, it just started working again on it's own. Here is a previous thread on it though that might help some.
trunk will not close!
Old 06-21-2006, 05:35 PM
speedie's Avatar
Eine Kleine Panzer
Lampasas, TX, USA
Car: 1968 Bug 2001 New Beetle 1.8T 2003 New Beetle 2.0
I had the same problem. Remove the trunk hatch interior black plastic piece by unscrewing the screws (found inside of the grip handles) and then pulling the plastic piece off of the trunk lid. A bunch of clips hold the piece in place so pull gently around the edges and they will come out. I then lubed the entire latch mechanism with white litium grease. Have not had any problems with closing since then.
Old 06-21-2006, 09:04 PM
chaddicus's Avatar
Volktron
Troy, AL, USA
thanks, the dealership says it's still under warranty so I'm taking it up there on Saturday and have them take a look at it. Thanks for the help though, if they try to charge me I may just do it myself by your method.
Old 06-21-2006, 09:47 PM
I have the opposite problem... mine won't open.
If I want to open my hatch, I have to use the key fob and lift the hatch by hand as a press the unlatch button. If I release the button without lifting the hatch, it is open, but I cannot raise the hatch--it is stuck. I can close it by pressing hard downward. Is this a lube issue or an adjustment?
Cheers
Trunk Problem! casper98 Questions, Issues, Concerns, or Problems with the New Beetle 0 04-23-2006 10:37 PM
cant close the trunk eidurth The New Beetle Experience 11 04-14-2006 08:34 PM
Trunk Sensor animex Questions, Issues, Concerns, or Problems with the New Beetle 3 03-18-2006 08:20 AM
Noise in the trunk ALLIECON 2.0 Liter Gas 3 01-24-2006 02:22 PM
