'99 Fan Switch Problem - NewBeetle.org Forums
Old 06-29-2006, 09:29 PM
Odessa, FL, USA
Car: GLS
Question '99 Fan Switch Problem
I live in God for Sakin' Florida so it's imparitive to have A/C. Well wouldn't you know it, my fan switch broke as I turned it to start the A/C working in my bug. It's a mechanical issue since the switch kind of stuck and as I tried to work it, it just gave out. The switch still has the reassuring integral level feel but the fan doesn't turn on.
So, my question is, how can I get the dash off so I can look at it / fix it. I'd buy the manual but I can't wait that long to get it fixed. To darn hot!!
Old 06-29-2006, 09:38 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
If I recall correctly, the two blanks on either end of the emr. switch/ rear def. housing just pry off. Thereshould be a couple of screws to release that whole assembly below the fanswitch housing. Perhaps you can access it from there...
Old 06-30-2006, 03:35 AM
75 year old car nut
Tucson, AZ., AZ,
Car: '99 NB-GLS--"85 Cabrolet
Default A/c
Did you check the fuse??? When mine quit the a/c nor the recirculate light would come on, and sure enough, it was the fuse!
Good luck, Earl
75 year old car nut
Old 09-02-2010, 02:29 AM
Default Ac/heater fan switch
If the problem is just the fan switch will the AC button lite work or not?
My AC LITE doesn't lite up when pressed.
Old 09-02-2010, 02:35 AM
All the time? I'm pretty sure my AC light only comes on if the fan is on.
I think there is a light behind the button that can go out though. Does your recirc light work?
Old 09-02-2010, 06:31 PM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Make sure the vent switch is not turned to defrost setting or towards the top for windsheild only or else the A/C will NOT turn on and the light will be off. The selector switch for the vent must be in any position BUT defrost then the a/c and the light will be on.
Ignition Switch problem - Turbo S turbojdub Questions, Issues, Concerns, or Problems with the New Beetle 1 06-17-2006 12:31 AM
on off switch for electric fan? jazzcat 2.0 Liter Gas 13 01-16-2006 01:45 AM
Cooling Fan Problem takarick 2.0 Liter Gas 5 01-12-2006 04:15 PM
electric fan problem jazzcat 2.0 Liter Gas 6 01-05-2006 02:30 PM
Fan on fan off prudence Questions, Issues, Concerns, or Problems with the New Beetle 0 10-09-2005 11:15 PM
