help with headlight wiring
i just bought a brand new bosch OEM headlight assembly, driver's side for my '98 beetle. apparently bosch has changed their wiring because it's different from the pass. side. i'm looking at a green wire and a yellow wire and i need to know which is for low beam and which is high beam.
also, i read somewhere that i should apply some kind of silicon or powdered graphite lubricant on the rubber seal before installing. is this true or could someone give me some insight into exactly what i need to do to install this thing 100% properly? i'd like to get this done right the first time so i don't need to deal with it again anytime soon. THANKS!
