Trunk Light - NewBeetle.org Forums
Old 07-03-2006, 05:31 PM
analogmax's Avatar
Default Trunk Light
Anyone know where the switch is for the trunk light on a 98 beetle? Mine does not work and after going through everything I found that the P O had disconnected the connection in the deck lid. When I plug it back in the trunk light will not go out so I am assuming it must be a bad switch. Thanks.
Old 07-04-2006, 05:30 PM
Morristown, NJ,
Car: 1999 GLS 2.0
I have a 99 beetle and the truck light doesn't come on. Neither does the trunk-open indicator in the dashboard. Here is the information I found that should solve my problem and hopefully it'll be helpful to you as well.
http://forums.vwvortex.com/zerothread?id=945378
Old 07-04-2006, 06:12 PM
analogmax's Avatar
I will give that a try
Thanks!!
Old 07-06-2006, 01:17 AM
analogmax's Avatar
Default Updated:Trunk Light Problem
Ok I figured out my problem. I plugged the wiring back in and the light came on, when I close the deck lid it stays on. I opened the deck lid and closed the latch with the lid up and the light went out. I called the dealer and found out that you cannot replace just the switch you have to replace the entire latch for $42.00.
I pulled the latch and cleaned and greased it but still no good. I finally figured out that the latch was not closing all of the way, the latch has two clicks on it and it was only going past one. The only thing I could find was a rubber stop on the latch itself that was stopping the lid from going all the way down. I removed the latch cover and pulled the rubber stop off and now it works great. I even had problems with the deck lid not closing completely before but now it is rock solid. BTW my car is a 98
Old 07-06-2006, 01:21 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Outstanding description of the solution. Kudos to you on your "self-repair".
Old 07-07-2006, 02:56 PM
dunno513's Avatar
dunno513
Alton, NH, USA
Car: 06 TDI NB w/DSG
Nice work.
I just wonder, rather than entirely removing the rubber stopper, if shaving it down a couple mm's would be better. I just wonder how much that may aid in keeping tension on the latch once closed. Any new rattles?
Old 07-09-2006, 05:25 PM
analogmax's Avatar
no rattles at all. it actually closes tighter than before
Trunk light doesn't come on IHeartNB Questions, Issues, Concerns, or Problems with the New Beetle 5 12-04-2007 05:16 PM
Opening the trunk... Joranthalus New Beetle Convertible 19 12-03-2006 11:13 PM
trunk will not close! CHEEZYSPAM Questions, Issues, Concerns, or Problems with the New Beetle 10 07-27-2006 06:33 PM
Trunk Problem! casper98 Questions, Issues, Concerns, or Problems with the New Beetle 0 04-23-2006 10:37 PM
Noise in the trunk ALLIECON 2.0 Liter Gas 3 01-24-2006 02:22 PM
