Cant stop getting pulled over. help! - NewBeetle.org Forums
Old 07-04-2006, 11:14 PM
mmmmmMMMMEMBER!!!
Carrizo Springs, TX, USA
Car: 2000 Silver GLS v3.1
Default Cant stop getting pulled over. help!
One of my tail lights doesnt work anymore. The bulb is fine.
It appears there is a loose wire in the engine compartment. Seeing as there is no bulb, or socket for that matter, for the front turn signal/running light.
I need to know wich wires to splice so I can get that light working before I get a ticket. So far, since I know all the officers and I work with the EMS, I havnt gotten a ticket yet.
Old 07-05-2006, 12:15 AM
detailstation's Avatar
Night Prowler
IN,
Car: 99 black nb-work in progress
Default ?
how do you know the bulb is fine? just because it looks okay really doesn't mean it is!check it or put a new bulb in first!
Old 07-05-2006, 03:30 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
The common cause is a bad ground.
With the bulb removed, and the lights on check to see if you have voltage at the socket. Then check to see if you have a path to ground from the socket.
Old 07-09-2006, 06:06 PM
mmmmmMMMMEMBER!!!
Ille try that when I have some time. Its not just that tailight that doesnt work, its all the running lights on the right side. Could it be one of the smaller fuses? Because 2 of those are out.
Is there a diagram somewhere for the fusebox? Because the little diagram on the cover for the fuses only shows the larger ones.
Arrgh make it stop!!!! SAMPO Questions, Issues, Concerns, or Problems with the New Beetle 1 06-29-2006 05:44 PM
OMG!!!! I can't stop starring at this!!!! Fowvay Miscellaneous Hoo-Ha Archive 23 06-29-2006 01:20 AM
Engine Stop after 20 min. (more or less) coiae Questions, Issues, Concerns, or Problems with the New Beetle 2 04-10-2006 06:52 PM
CEL Code pulled a Air Fuel Metering conceptzj 2.0 Liter Gas 2 02-16-2006 05:55 AM
