Brake Switch Problems - NewBeetle.org Forums
Old 07-06-2006, 04:28 AM
Default Brake Switch Problems
Ok, so I need any advice, I am baffled. So over the 4th I did a couple things to my Beetle. Changed the brake light switch, I also had my radio out so I could install a new center dash piece. After I was done and reconnected the battery and all, the brake light on the dash was lit up, so was the abs light. If I try to drive it, it beeps at me, also maybe unrealted or not, but my outside temp gauge isn't coming on and I can't set the clock time.
Any suggestions? Might something need to be diagnosed with the computer? Did I do something wrong? Any help would be great.
Cheers,
Jeff
Old 07-06-2006, 06:27 PM
jackfrost's Avatar
and your little dog too!!
Gurnee, IL, USA
Car: 2000 Cool White glx
did you check to see if you popped a fuse? are the brake lights functioning?
Old 07-07-2006, 12:28 AM
I had the same problem with my 98. The cruise would not work, outside temp wouldn't work and the clock kept resetting itself everytime the car was turned off. If you check your fuse panel, the 7.5a fuse is blown. Replaceing it last only a short time. The fix was to take the N.B. to the local dealership and they replaced the brake light switch. Mine was a recall item, yours may also. Call your local dealer and ask.
Old 07-07-2006, 02:52 AM
Thanks for the ideas, I will check em out. If no luck them off to the dealer I guess, hehehe
Thanks
Jeff
Old 07-09-2006, 01:12 AM
Default Kinda fixed it
Well I kinda fixed my problems. Yep there were 2 blown fuses, not sure how both of them popped but oh well. I think I have messed of the new switch I bought though. Maybe been pushing it too hard in frustration, it doesn't relly click anymore, so I need to get a new one on monday and try again.
Thanks for the help
Brake Switch Replace - How-To marvins_dad Technical How-To 1 09-20-2006 01:48 PM
Brake Light Switch larryziegler Questions, Issues, Concerns, or Problems with the New Beetle 3 05-24-2006 02:43 PM
brake light switch atticus Questions, Issues, Concerns, or Problems with the New Beetle 7 05-13-2006 10:32 PM
Brake Light Switch brwnidgrl New Beetle Convertible 2 04-20-2006 04:38 PM
What's with the stupid brake light switch.. rcy Questions, Issues, Concerns, or Problems with the New Beetle 5 02-25-2006 04:48 PM
