trunk/hatch won't open all the way by remote - NewBeetle.org Forums
Old 07-30-2006, 04:54 AM
Default trunk/hatch won't open all the way by remote
I cannot get my hatch to open without standing right there and pulling it up right after I press the key fob or right after pulling the driver's side door button. If I don't catch the lip right away the hatch won't open all the way.
There are two distinct movements. The first happens, but if I don't pull the hatch before the second sound it won't open. It is loose, and the only solution is to press the button again and lift it manually.
Because of this problem, I cannot use the interior button unless someone else is with me. Is there an easy fix?
Cheers
Old 07-30-2006, 04:57 AM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
Yeah, when you use the remote, be right there and catch it, or when you use the button on the door, have your windows closed, press hte button and close the door. the air pressure will pop it up.
There are tabs on the side of that hatch that can be adjusted, but that didn't work for me.
Old 07-30-2006, 08:33 AM
member
Toowoomba, South-East Queensland, Australia
Car: 2005 1.6l automatic sunflower
I thought the problem used to be boot lids that were difficult to close because of the spring which assists in the opening of the boot was too strong to allow easy closing. The fix was to do something or other with the spring which is under the latch on the boot lip - maybe someone has taken too much pressure off and this is preventing the boot popping up.
Old 07-30-2006, 01:22 PM
Toad's Avatar
Mableton, GA, USA
it does seem that people either have trunks that dont open, or dont close right. Guess vw just didn't find the right balance.
Old 10-06-2006, 08:48 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Well, I've been neglecting this little annoyance for years now.
"ptmlinh", who is very nice, and I have been swapping PMs over this and I finally just got off my butt today and did it.
Acquire (read: buy, steal, trade etc.) a T-30 Torx driver and loosen the fastener holding the black rubber bumper on each side channel of the hatch. Move the bumpers about 1/4" towards you and tighten firmly.
Mine now "pops" out fine...
Old 10-10-2006, 05:19 PM
2000
Portland, OR, USA
Car: 2000 New Beetle GLX 1.8T
I'm having the same problem, and I just located my torx drivers last night. I'll have to adjust it and see if it works for me.
I've also heard this problem can occur due to the hatch release motor starting to wear out. Has anyone ever heard that before or replaced the motor as a fix?
Old 10-10-2006, 05:34 PM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
kingofgrills, we must GTG!!
My hubby is also a "king of grills"...... (he BBQ's year round, that is )
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 10-10-2006, 07:21 PM
Cool
Well let us know if this adjustment works for you, as well...
Old 10-31-2006, 03:28 AM
Wazabi_Al's Avatar
Wazabi gone...
Gilbert, AZ, USA
Car: 2004 Turbo S - PGM
Soooo...anybody have success with the 'adjustment'?
Anyone have any pics of the exact locations of the "fastener holding the black rubber bumper on each side channel of the hatch"?
"I'm also for trade because it, it, it, it's like makes sense." -Dubya
Old 10-31-2006, 04:39 AM
Cool
On my '99 it's located just below where the air struts anchor to the body...
Old 10-31-2006, 07:38 AM
Hindenburg's Avatar
Captain Off Topic
El Paso, TX, USA
Car: 2001 NB GLX Techno Blue
Default slightly off topic
Is the hatch supposed to open with the handle under the swivel VW logo? Cause when I lift up on the handle I can hear a microswitch clicking, but nothing happens. ANd yes, the car is unlocked.
Old 10-31-2006, 02:34 PM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I've never tried that.
On another note, I removed my hatch interior panel to change out my 3rd brake light and was presented with nuts falling out ... they went to part of the latch assy. You guys may want to check to see if it is all bolted in good, mine wasn't and that was 2 years ago before the harsher suspension.
Open hatch sensor comes on, causes alarm? ChuckDubDub Questions, Issues, Concerns, or Problems with the New Beetle 10 01-27-2010 04:53 AM
Car Thinks The Hatch Is Open When It Is Shut? teklein Questions, Issues, Concerns, or Problems with the New Beetle 6 07-28-2006 06:28 PM
HOW-TO replace the remote rear hatch actuator XCman Technical How-To 5 07-28-2006 04:51 PM
Help !! Can't open trunk Naen 1.8 Liter Turbo 1 06-06-2006 03:50 PM
Power Trunk/Hatch Relay? Gelby Questions, Issues, Concerns, or Problems with the New Beetle 0 11-29-2005 07:03 PM
