Signal Lights Gone Wonky - NewBeetle.org Forums
Old 09-16-2006, 04:32 PM
Car: 2001 Silver Arrow GLS
Cool Signal Lights Gone Wonky
Two days ago my signal lights started going "wonky."
The first thing they did was alternate between their regular "tick tick tick" and a faster "tick tick tick." Now, they hardly "tick" at all. Not only do they stop ticking, the light on my dash doesn't show either. My bulbs (the actual light bulbs on the exterior) all seem to be fine.
A call to my local dealership says that it would be the flasher that's gone - except that my four-ways function correctly.
Any ideas?
Old 09-16-2006, 04:39 PM
Grover's Avatar
Garland, TX, USA
If I remember most of my old cars, the 4-way was a sepearate flasher from the regular one. Don't know if this is true on the bug. It does sound like the flasher to me. It is a cheap part-cant hurt to try it out....
Old 09-16-2006, 05:37 PM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
Could be two things:
1. For me it was my hazard switch. Replaced for $30.
2. For my sister it is the actual blinker stem. You know the thing you use to turn on/off the blinker. This is a pricier replacement. $200+ stem and labor. They have to take the steering wheel off. HUMPFT! :O
J'veux pas mourir tout seule.
Old 10-06-2006, 08:52 PM
helga's Avatar
TX,
Car: 2001 White TDI
Default Bad hazard switch??
Don't know if you got this fixed yet... but...
Same thing happened to me last April. This July I took it to the shop and they replaced the hazard switch. On my 2001 TDI,the hazard switch not only is for your Hazards, but also the blinkers.
Hope this helps!
Old 10-07-2006, 10:36 AM
mgwerks's Avatar
Cherchez la coeur...
Bandera, Republic of Texas,
Car: Oso - a black 99 GLS TDI
Yeah, they pulled this trick on some old air-cooled VWs too - but I'll tell you that was a lota more $$$$ than the $30 NB part!
Your fog lights are on,
It isn't foggy today -
You are a doofus.
Old 10-07-2006, 01:02 PM
73standard's Avatar
Jacksonville, FL, USA
Car: '99 NB/ '73 Standard
I know for mine all the bulbs seemed fine, but it turned out that my passenger side front bulb was bad, even though it didn't look like it.
Old 10-07-2006, 01:10 PM
Crystalgolem's Avatar
Hendersonville, TN, USA
Car: 2001 Isotope 1.8T AWV Manual GLS
Mine did the exact same thing. The Hazard Switch will fix it. ECSTuning has them for a good price. Its a 5min. fix.
CRYSTALGOLEM
Words are words; actions are the evidences of the character wrought by their creator.
Old 10-12-2006, 12:38 AM
killerbug's Avatar
My steed is Killer
Rochester, NY, USA
Car: 2004 New Beetle Convertible Turbo
Killer's right turn signal was acting up (blinking 2x faster than the left side) so when I took him in for an oil change I had them check it out. Initially, it seemed they fixed it, but before I was even out of the dealer lot it started up again. So I drove right around back into the bay and the guys looked at me like I was nuts. I showed them, and half hour later was back on the road. They said something about the new guy put the bulb in backwards (?). Anyway, halfway home, it starts again. It's intermittent, sometimes blinking will be OK then it speeds up mid-blink. Naturally, this means it will not happen when I take it back to the dealer :roll:
You guys think it's the hazard thing?
Driver found
1st: Heidi, '87 Jetta GL, white
2nd: Violet, '95 Cabrio GLS, violet
3rd: Killer, '04 New Beetle Convertible 1.8T, reflex
Old 10-12-2006, 12:12 PM
mrbeetlebrain's Avatar
pixel pusher
Perth, Australia
Car: 2006 MKV GTI
If the blinker blinks twice as fast you've got a blow blub, if the blinkers blink strangely or slow down or stop - blow hazard unit.
Cheers, paul
2006 Red MK5 GTI - DSG, Leather, Sunroof, Sat Nav, Xenons || Sold! 2002 Turbo New Beetle
Old 10-12-2006, 01:45 PM
Where is home ....
Cheers, paul
I don't think this is entirely accurate. Sister has blinkers that are 'wonky' ... they slow down, speed up, stay on, don't blink at all ... someimtes they are normal. We changed out her hazard unit and it didnt fix it. The dealership (not that I trust them 100%) said that it is her blinker stem itself. 0_o
Old 10-13-2006, 06:59 AM
pixel pusher
Perth, Australia
Car: 2006 MKV GTI
You could be right but my hazard unit used to slow down, speed up, beat out of time and stop - and if you think about it all the blink stem is doing is telling the hazard unit to start working, and the "click - click" pulse is coming from the hazard unit itself.
Anyway, if your doing the work yourself you're going to change the hazard unit before you bother doing the indicator stem.
Was it under warranty or did they charge?
Cheers, paul
Anyway, hopefully we'll get confirmation on what was wrong.
Turn Signal Popped Out! Ted 2.5 Liter Gas 3 09-04-2006 04:57 PM
XM signal dropping out? skittles Car Audio 5 07-13-2006 01:29 AM
Need a turn signal lever XxchavoxX Market Place Archives 1 06-07-2006 07:13 PM
Turn Signal Issues 73ladybug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 02:16 PM
How's this for some Wonky Boost control :) Growler Miscellaneous Hoo-Ha Archive 2 12-17-2005 02:56 AM
