Turn Single Issues - NewBeetle.org Forums
Old 01-12-2017, 02:32 AM
GeorgeG97322's Avatar
OR, USA
Car: My daily drivers is a Rav4, my bug is in resteration mode
Garage
Default Turn Signal Issues
Here we go...
Replaced right rear turn signal light bulb, all was well for about a week, now all lights are working, Hazard lights work correctly and all light up. Left turn signal works the same as hazards. The right turn lights however blinks twice as fast as if a bulb was burned out. I'm thinking that the hazard relay switch is ok because the hazard lights work correctly. Just as a side note, the cruise control is not working and I have I believe narrowed that down to the turn signal switch on the column. Anyone out there have any suggestions or similar issues
Thanks,
George
Old 01-12-2017, 02:46 AM
Rochester, NY,
Car: 1999 GL 2.0
The right rear bulb could be not twisted fully into place, so that contact is being made with both filaments instead of each individually, or the bulb is defective. If both filaments are are on the current draw will be too much leading to the fast blinker. Also, the right turn signal will deactivate the cruise control since the brake light is being powered as well.
Old 01-12-2017, 02:55 AM
OR, USA
Garage
Red99,
Thanks for the input. I'll recheck the bulb installation. I found once that by jiggling the turn signal lever and engaging the cruise I was able to get it to work (only Once). I don't have a full history of the car, but I'm sure it was in an accident causing front left damage (new front headlight) which doesn't like to stay in the receiver and other indicators.
George
Old 01-12-2017, 04:26 PM
esse10's Avatar
Richmond, TX, USA
Car: 03 1.8 Turbo
Default relay
The hazard lights relay mounted at the center console right below the dash is usually the culprit.
Old 01-12-2017, 11:10 PM
Rochester, NY,
Car: 1999 GL 2.0
The tail/brake share the same bulb but the turn signal is separate so this is wrong. It is the tail light can interact with the cruise control.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
2002 turbo s front turn signal and marker light issues bft450 Questions, Issues, Concerns, or Problems with the New Beetle 2 10-09-2016 09:36 PM
Parking light/turn signal issues lizziebunny Questions, Issues, Concerns, or Problems with the New Beetle 2 07-24-2008 05:31 PM
You Must Be Single... niki Jokes 8 04-13-2007 03:30 PM
Evanscence's new single! EvilinaDM101 Miscellaneous Hoo-Ha Archive 12 08-01-2006 09:48 PM
Turn Signal Issues 73ladybug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 03:16 PM
