Help! Problems! - NewBeetle.org Forums
Old 10-01-2006, 12:55 AM
Bainbridge, IN, USA
Car: 2000 Techno Blue 1.8T GLX
Default Help! Problems!
I have a high mileage (125k) 2000 1.8T and have a couple concerns/problems:
(1) My DRL's don't work anymore! I know some people disable them on purpose but I didn't! Any ideas? Fuse maybe?
(2) After sitting for awhile and then starting there is a fairly high pitched whining noise. I can never get it to happen when my friend (a mechanic for GM) is around. I shut it off and immediately restart it and it goes away. Could it be the secondary air injection pump? That was my first thought.
Thanks for any help!
Old 10-01-2006, 02:27 AM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
The high pitched whine is definately the secondary air pump, mine sounds like a shop vac. Are you sure your low beams are not burned out? If the low beam portion of the headlight burns out the DRL's will not light up. Good luck.
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
Old 10-01-2006, 01:11 PM
Bainbridge, IN, USA
They work fine when switched on, but they will not come on without the switch being moved from the "off" position to the on position.
Old 10-04-2006, 03:34 AM
75 year old car nut
Tucson, AZ., AZ,
Car: '99 NB-GLS--"85 Cabrolet
Default DRL's
If the parking brake is up (on) only 1 click the DRL"s won't work!
It may be a bad switch, or an adjustment???
Earl
75 year old car nut
Old 10-04-2006, 05:42 PM
Bainbridge, IN, USA
Didn't think to check the parking brake, will check that as soon as I get back to my car (in class right now). I'm working on getting a new switch right now so maybe that will solve my problem.
Some of the Many Problems alexirkhin Questions, Issues, Concerns, or Problems with the New Beetle 22 08-08-2006 03:53 AM
AC Problems 02nbturbos Questions, Issues, Concerns, or Problems with the New Beetle 4 08-02-2006 04:29 AM
problems scrnamessuc Questions, Issues, Concerns, or Problems with the New Beetle 0 04-12-2006 11:49 PM
Help with Problems AmyWalker 2.0 Liter Gas 6 12-28-2005 06:35 PM
A Few New Problems Mortville Questions, Issues, Concerns, or Problems with the New Beetle 25 11-19-2005 12:48 PM
