Phanton CELs - NewBeetle.org Forums
Old 10-11-2006, 05:29 PM
lebicicletta's Avatar
Granville, OH, USA
Car: 2002 Turbo S; 2002 Passat; 67 Porsche912; 81 Vanagon Westfalia
Default Phanton CELs
For several months now I have had a random CEL that comes and goes - light usually on for a couple of weeks, then off the same. 2002 NBTS Codes indicate everything from misfire to cat converter below optimal temp, to vapor recovery leak.
Any thoughts? Note: I did have the gas tank replaced (twice, under warranty) and the dealer that did the work had "issues."
Any clue as to why the light would go off on its own??
Any advice appreciated. Thanks!
Old 10-11-2006, 05:34 PM
FlwrPwer's Avatar
Fishkill, NY, USA
Car: '07 Triple White NBC
My CEL does this all the time...usually in the winter time. My dealer told me its environmental. I think thats They have yet to find a problem with the car.
I stopped bringing him in and instead, named my CEL Chimmy-Changa. He comes and goes as he pleases to check in on me every now and then
Old 10-12-2006, 12:59 AM
dunno513's Avatar
dunno513
Alton, NH, USA
Car: 06 TDI NB w/DSG
I used to have a Ford p/u that I chased a CEL for 60k miles. I can't remember when it was on/off, but it was seasonal. It came on for the first time just after changing my air filter at 37k.
Around 100k miles I replaced my air filter (probably the 4th) with the OEM Ford air filter and I never saw the light again.
After chasing the CEL while under warranty, and being told that a solid CEL on the ford p/u's was emission based I never had a care to investigate while the vehicle was running well. Sorry enviornmental folks, but my wallet was more important than "wondering" if that light actually meant anything.
Point of this post being, I strongly suspect that my use of cheap generic air filters caused my CEL's all those miles.
Old 10-12-2006, 09:28 PM
Granville, OH, USA
thanks!
Old 10-12-2006, 09:32 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Did you check the gas cap? Is it on correctly? Is it a new one? Do you need a new one? Just a thought.
Help Needed With Cels brentnnc 2.0 Liter Gas 1 08-28-2006 04:45 PM
