On the "stick" on the left side (same as your turn indicator), you should find the Cruise Controls. There's a sliding switch on top, and a push-in button on the end of the stick.
To turn off the CC, move the sliding switch all the way to the right. There should be a click that'll lock it in place. To turn on the CC, push the sliding switch all the way to the left. Hold it there for a second or two for the CC to engage. Once you let it go, the switch will settle in the middle. To slow down while cruising, push in the button on the end. To speed up while cruising, push the sliding switch all the way to the left. You can also disengage the CC by braking.
1998 Red New Beetle 2.0 Automatic |
My CC on my 98 is different. Pull the switch to the end of the stick to turn it on, press the button on the end of the stick to engage it. My stick only has on/off switch and a set button.
on the 02 models the CC is alot simpler.
One and off are a switch on the leftside arm. There's a toggle switch thing on the end of the arm. One direction will acclerate and the other direction will set the speed. You can also set the speed using your pedal. Braking will disengage the CC. Accelerating using the arm is a bit rough, so i always use the pedal to set my speed. Oh and for pdoel's sake, please only use this on highways!
I have the exact same problem. I got my '99 5 speed used and it didn't come with the owners manual either. I can't figure out the cruise control either.
It doesn't LOOK like it should be complicated. There's a toggle switch that said on/off, and a button on the end that said set. But with the toggle set to on, and then pressing on the set button for a few seconds, when I release the gas, I just slow down. I was thinking that since my car is used, maybe this feature no longer works. Luna Faye |
The cruise will also not work if the brake light switch is going out. Weird.
Shows how often i use the feature. ![]() |
| cruise control | 58herbie | Technical Modifications | 0 | 08-06-2006 07:07 AM |
| my cruise control died | oilspot | 2.0 Liter Gas | 1 | 07-06-2006 03:30 PM |
| cruise control | fiveshoes | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 06-16-2006 09:21 PM |
| cruise control on new beetle | BugRed | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 12-02-2005 11:09 PM |
| cruise control | albroumand | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 11-15-2005 02:42 PM |
