i have a 98 NB with 2.0 engine. i've had this problem for about 6 months now. when i first turned the key, the engine won't turn over, everything else seems to be fine, i heard the humming noise. then, it usually starts on the second turn of key. but recently, it's getting much worse, i have to turn the key on and off 3, 4 or even 5 times in order to start the car. once the car starts, it runs just fine. and i have a fairly new battery, both terminals are kept clean. any ideas?
thanks, |
thanks for the valuable input guys. i took the car to a shop(non vw dealer) for inspection today. the machanic said it was not the starter. the starter should be ok. however, he didn't want to fix it for me because he was not confortable with working on an vw. he suggested me to take it to dearler. but i am trying to avoid to take it to dealer because they always overcharge me. the machanic, however, did mention that it's mostly like the ignition switch. anyone know how to check the ignition switch.
thank you! |
Here's a thread initiated by "TOAD" regarding the ignition switch issue. Be sure to let us know how it goes...
http://www.newbeetle.org/forums/show...+switch+melted |
will be doing this tonight after i pick up my new compressor! tools make me happy...little update . battery still is good, no drain, problem goes away after starting the car or runing it for awile. when i try to start it after i park and drive somewhere it works fine but the initial start is the one it seems like it is struggling to start on.
| won't turn on! | lady bug | Car Audio | 4 | 07-09-2006 01:14 AM |
| How do I turn the TP function off? | paspin | Car Audio | 0 | 02-05-2006 08:25 PM |
| How do I turn the TP function off?! | paspin | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 02-05-2006 08:21 PM |
| lost of spare ignition key and backup key faulty(no data found)...PLS help | atomwhiz | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 12-11-2005 11:36 AM |
| lost of spare ignition key and master key faulty with no data found..help pls! | atomwhiz | Technical Modifications | 1 | 12-11-2005 11:11 AM |
