headlight silicone sealant gunk - how do i remove and where do i get some more - NewBeetle.org Forums
Old 10-23-2006, 03:29 PM
manoverboard987's Avatar
Lurker Status Assumed.
Car: 2000 Jetta GLS 2.0L
Default headlight silicone sealant gunk - how do i remove and where do i get some more
so a while back, sometime last year, both of my headlight bulbs blew at once. thinking it was something more serious than a fuse since they both blew at the same time, i took my car to a supposedly VW specializing shop. after an hour and a half of trying to diagnose any problem, they said they did all they could by changing both burnt headlights, and charged me $150 for their trouble. As i walk out to my car, i notice black gunk around the headlights, and conclude that the mechanic must have pulled off the lenses in trying to get the headlights out. i had just recently lubed the tracks, so i concluded it was his incompitence that was to blame.
well i've been cleaning it up little by little, and most recently, my passenger side lens fell off, so i'm trying to start anew in the sealant application.
i've used Turtle Wax Bug and Tar remover to get it off the paint, and it doesn't do much more than soften it up so i can smear it some more.
does anyone know of any chemicals i could use to clean the sealant gunk off my headlight assembly?
and does anyone know where i can get some more of that sealant (or comparable) to fix it up?
thanks.
(and if anyone has a spare passenger side headlight assembly laying around, i'll take it off your hands - send me a PM.)
Old 11-24-2006, 11:36 AM
Founder of TeamFoolie.com
Wichita, KS, USA
Car: MK4 Jetta 1.8T/MK2 Gli 16V
Clean Green is always a good start, let it sit for a few min and then have at it.
Not that i advise this, but brake clean will take anything off, including the clear coat. So you make the call.
As for the seal, not sure what to use.
Yellow gunk on oil cap. Toad 2.0 Liter Gas 13 12-20-2006 05:34 PM
Silicone Hoses turbs01 1.8 Liter Turbo 2 04-26-2006 07:05 PM
Would love to remove headlight kentbgivens Questions, Issues, Concerns, or Problems with the New Beetle 5 02-07-2006 08:08 PM
Oilpan sealant jbehm 2.0 Liter Gas 2 02-01-2006 02:31 AM
What kind of Silicone Lubricant to select? u2u2u2 Questions, Issues, Concerns, or Problems with the New Beetle 3 12-07-2005 12:50 PM
