Originally Posted by Porkchop
No, the exhaust doesn't have to be unbolted. But the pancake pipe does have to be removed (that goes to the intercooler). Also, it makes it easier to remove the coolant pipe that goes to the turbo or otherwise you cannot get the engine mount totally removed and out of your way to work on the tensioner. Oh, and don't remove the pin from the new tensioner.
Great! Thanks for the info. If you can think of any other helpful hints, send them my way.
Best deal on parts would be from Metalman.
We've already ordered a kit from ecs that comes with timing belt, tension roller, tensioner assembly, idler roller, Hepu water pump with metal impeller, accessory drive belt, thermostat, and gold under drive pulleys. We also ordered 2 bottles of G-12 and new stretch bolts for the motor mounts. Should we need anything else?
