Oil leak after 1rst oil change. - NewBeetle.org Forums
Old 01-19-2007, 12:42 AM
Birmingham, AL, USA
Car: 2006 Beetle
Default Oil leak after 1rst oil change.
My wife's brand new 2006 beetle now leaks oil from the oil canister after it's first oil change. Dealer is aware of this, has anyone else experienced this?
Old 01-19-2007, 02:54 AM
blackonblack's Avatar
Howdy
Taylor, TX, USA
Car: 2003 GLX NBC, 06 NBC PKG2, 06 Golf
They may have not used the proper drain tool to drain the housing. Alot of people just use a screwdriver to push the drain valve over end up damaging it. There is a proper tool for just this reason. This is the tool for draining the oil filter housing.
Old 01-19-2007, 07:07 PM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
What's an oil canister? I had to swap my oil plug for an oversized one when I found it was stripped and oil would slowly leak out. I also wraped the oil plug with a little plumbers tape...no more leak.
- Joe
Old 01-19-2007, 11:16 PM
OH, USA
Car: 03 GTI
As wise as you are Hudson I'm surprised you don't know about other types of oil filters besides what is on your NB. It is simply that the metal outer case of the oil filter is permanent and only the guts/element gets replaced. Here's a picture. TDI has been like this a while and I assume so is the new 2.5L 5-banger.
Old 01-20-2007, 12:13 AM
I've never heard of such a thing and why would anyone bother? What do you do....just change the inside of the filter? Sounds like a needless mess to me personally. I'll stick to the more conventional spin-on oil filter replacement. LOL...sorry my wisdom doesn't include filters like that.
Old 01-22-2007, 04:38 PM
OH, USA
Car: 03 GTI
I agree, the spin-on seems like much less hassle and mess. Yes, you just change the inside and the tool pictured earlier is used to drain the housing.
Remember the old oil baths? Now those are messy. I have one on my 1960 Ford tractor and a few of my old air-cooled Dubs had them.
Old 01-22-2007, 04:59 PM
kaiser's Avatar
no longer use this site
torrington, CT, USA
Car: 01 techno blue t3/t4 big turbo
i'm sure the tech that did your oil change didn't have the tool pictured above, so he stuck a screwdiver into the little drain "nipple" and damaged it.
the first time i changed the oil on a new 2.0t/2.5 i couldn't believe my eyes. it's a stupid contraption for sure.
sold the beetle, don't use the site anymore
Old 01-23-2007, 12:39 AM
Birmingham, AL, USA
Car: 2006 Beetle
Thanks for your replies, my problem is that the canister is leaking between itself and the engine block. It has had two new canisters installed in an attempt at a fix without success. I was thinking it was a known bug and others were experiencing the same problem. It's at the dealer now while they take another crack at it.
Old 02-13-2007, 11:45 PM
lloyd's Avatar
lloys
aurora , CO, USA
Car: 1999 GLS Beetle, 2001 Corvette Convertible, 2005 V8 4Runner
What turned out to be the fix for your oil filter leak?
Old 02-14-2007, 02:37 AM
Birmingham, AL, USA
Car: 2006 Beetle
It just went back yesterday for the forth attempt.
Old 03-11-2007, 11:04 PM
Birmingham, AL, USA
Car: 2006 Beetle
Well it looks like the dealer got the problem resolved. Some part above the oil filter was cracked, no leaks now.
Old 03-12-2007, 02:44 AM
wasting my time in Cancun
Cancun, Quintana Roo, Mexico
Car: 2003 New Beetle GLS 2.0 Stick
TG to the american vw dealers! and the warranty of course...
Old 04-09-2011, 08:59 PM
woody95124's Avatar
volks r cool
san jose , CA,
Car: 2008 vert beetle
Default oil drain tool
Hey black on black...where do u get tht drain tool for canister??thnx in advance
Old 04-09-2011, 09:04 PM
MyOtherRidesAVette's Avatar
Thumbs down
b.o.b. hasn't visited the org since 11/27/07. Probably moved on! Maybe someone else will offer up the answer.
MORAV
In der Automobil-Scheune
HELP!!! Oil Leak wildman 2.0 Liter Gas 6 12-24-2006 12:09 AM
Oil Change??? scoester 1.8 Liter Turbo 3 07-19-2006 04:50 PM
Oil Leak - From valve cover?? zmladen 1.8 Liter Turbo 3 04-24-2006 03:52 AM
Oil Leak????? Jarhead96 1.9 Liter TDI 6 03-29-2006 11:29 AM
2001 NB With a bad oil leak! McYoda 1.8 Liter Turbo 1 01-19-2006 09:53 AM
