I had to replace a hub on my wife's 01 New Beetle so, while I was into it, I decided to replace the rear brake pads and rotor. Upon reassembling, I ran into a problem on not getting the piston to retract. I have never had a problem on any other car. I even tried opening the bleeder a bit to see if I could release some pressure. I need to get this together today, anyone have any ideas?
You need a special tool to reset the calipers on the rear, if you do it incorrectly you will break the parking brake funtion of the caliper. You may be able to find a rental kit at stores like AutoZone ... and if you hang with any other MKIV Dubbers, one of them may have the tool you need. I have the metalnerd tool that you can get here http://www.metalnerd.com/cat08.htm
Yes, you need that special calipher tool to get the rear brake pads on. I was able to borrow one from Canadian Tire, for a returnable deposit. No cost, once returned.
Thanks all. Due to the bad weather I wasn't able to get out and get the right tool, but the channel lock idea worked. The parking brakes still seem to work so I don't think I did any damage. Though they are extremely tight now. Is there a cable adjustment anywhere? The rear brakes were worn pretty good. I screwed in the pad as far as I could get it. I did notice that the driver side rear did not release real good before I started with the brake job. I may have a caliper going bad. |
| Brake problems after changing rear brakes | D_GR8_1 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 10-18-2006 07:44 PM |
| Brakes | captbp | 2.0 Liter Gas | 5 | 10-04-2006 10:19 PM |
| 25,000 miles and new rear brakes | finklejag | 2.0 Liter Gas | 6 | 06-18-2006 07:30 PM |
| Rear Brakes | Willard | 1.9 Liter TDI | 4 | 04-01-2006 12:20 PM |
| 1-160 mph /Stock brakes (front&rear) | tonysailor | Market Place Archives | 0 | 02-08-2006 12:58 AM |
