Well it all started with the CEL light coming on then my gas gauge showing full when I knew it wasn't. I try to fill up with gas last night and it won't let me pump any gas it keeps kicking off the pump. I think it's the pump so I go to another one and the same thing happens...I have to force fuel in and manage to get 2 gallons in. I'm thinking the charcoal canister might be clogged making the tank think it's full??? My question is where is the charcoal canister? Thanks in advance.
I've seen something like this before on a Passat. The left rear fender liner on a Passat got torn off and the owner didn't want to spend the $30 for a fender liner:
The problem was that since the fender liner was missing, the LDP and it's air filter were not protected, this allowed water to get into the charcol canistor. When trying to put gas into the fuel tank, air was not able to be displaced and created a back pressure at the filler neck. The fuel pumps were shutting off like they were suppose to. He purchased a fender liner along with some other items at a cost of a LOT more than $30. So, for your car, why isn't air getting displaced when you try to fill up? Missing a fender liner? ![]()
First I've heard of such a thing. You could pour water in the tank and the guage would read correctly. I don't see a bad tank of gas harming the sending unit (a bad charcoal canister won't keep you from filling up). More likely a coincidence. After that shell truck filled up, another companies truck was behind it filling up. Many companies use the same refineries. If you're filling the tank and it shuts off, especially if you've tried more than one pump. it's full! A bad sending unit may be the problem but, that can't keep you from filling the tank...and a bad tank of fuel isn't the likely cause. High sulfer content could damage the cat. converter but probably not much else...and not with just a tank or two.
- Joe ![]() 2001 Techno Blue Pearl 5 spd GLS. Heated leather, fog lights, power sunroof, alloy wheels. |
Hudson ... Shell paid to fix a lot of peoples fuel tanks .... lots. And that may be the way they run it around your part of the country, but here in the Oil Belt, when the other trucks pull up to the Shell Refinery a few miles up river from us, Shell is also responsible for the customers that get that gas, either that or they start buying product from one of the other dozen or so refineries. And I will hand it to Shell ... they paid all claims, even some illegal ones, some of those folks were sitting in NOPD when Katrina Hit.
Its not unusual in these times of high fuel prices for someone to 'milk' your car. To perform this somewhat illegal operation they will usually grab someones garden hose, cut maybe 2 metres off, shove it down your petrol filler hole and syphon as much fuel out as they can. Then they try to pull the hose out but the flap inside the filler wont let them do this - so they pull and pull till the hose breaks and you have either or all of the following;- blocked filler tube....fuel gauge stuck due to hose blocking float or a lenght of garden hose sticking out of your petrol tank.
Also heard that some fuel additives can soften and degrade the float which measures the fuel level in your petrol tank causing it to sink or soften and stick. |
LOL...Stealing I understand happens. I've never heard of people going thru all the trouble though of trying to siphon gas out of someones tank though. Sounds a bit over the top...no? |
I happened a lot when gas went from 28 cents a gallon to $1.15 a gallon in the 70's ... I wasn't driving yet, but sat through a number of rationing lines, in 78 or 79 I was in CA ... they were worse there than anywhere else. People would steal your gas while you were waiting to get gas, you had to get in line right after you hit half tank so you had enough to make it through the line .... people were stupid like that. |
LOL...I'm glad I wasn't aware of crap like that. We live in an area, lucky I guess, where we don't lock doors. Geez...I hope it never happens around here. 35 years here... sofar we've been lucky. |
All (he is) saying...is give (war) a chance... [apologies to John Lennon] "Nibblin' on spongecake, watchin' the sun bake, all of those tourists covered in oil..." "Your Freudian slip is showing..." "Reality is just that surreal time between my dreams" - me |
| No click off during fill up?? Help! | CoriBug | 1.9 Liter TDI | 3 | 01-05-2007 03:48 AM |
| Fill Me Out! | niki | Miscellaneous Hoo-Ha Archive | 58 | 12-05-2006 04:17 PM |
| diesel or gas beetle? | robpad | 1.9 Liter TDI | 10 | 12-02-2006 08:25 PM |
| Anyone else think it's just WRONG to spend $41 to fill up a VW? | jakabedy | The New Beetle Experience | 50 | 08-14-2006 03:02 PM |
| 1.8 turbo gas beetle stuck in 3rd | speedsk8er | Transmission Talk | 3 | 07-28-2006 03:10 PM |
