Driver's Side Door Problem - NewBeetle.org Forums
Old 02-11-2007, 04:37 PM
matone_05's Avatar
Slvr. 2001 NB 1.8T
Vidalia, GA, USA
Car: 01 NB GLS 1.8T, 5spd, Reflex Silver
Default Driver's Side Door Problem
Hello, has anyone ever had their driver's side door not open? Mine will not open, the door handle is kind of loose and you pull on the handle and nothing no click open sound. The door opens from the inside, but not the outside. Anyone else had this problem? How much $ am I looking at? Thanks -M@TT
Old 02-25-2007, 06:02 PM
MrRadi8's Avatar
Paducah, KY,
Car: 99 GLS
That's pretty much my problem but nobody is answering it.
Old 02-25-2007, 06:52 PM
DistantTwinkle's Avatar
San Antonio , TX, Uruguay
I dismantled my doors recently and have had a hard time getting the "cable" looped back in. That's probably your problem, the cable popped out and is probably hanging. I have no idea on the cost, you might be able to do it yourself. All it takes is a friend to help you out and removing 5 screws, three on the very bottom of the panel you'll need a 15 torq and two underneath the door handle. Just remember everything is plugged in, so you just want to hold onto the door while someone helps you out. You pop the cable into place so it won't move after you loop the metal hook back into the hole for the door. I hope this helps but I've been having trouble with my cables, as well. It'll take and after opening the door like 3 or 4 times it come loose. That's my issue right now. Good Luck
Old 02-25-2007, 07:11 PM
ristinkay's Avatar
ristinkay
Cranbrook, BC, Canada
Car: New Beetle 2001 1.9 TDI Silver Arrow Mettalic
I had it happen on my golf the whole handle needs to be replaced. it probably broke the mechanism that is. And Just so you know I never did fix the golf of that problem.
Diesel Fumes make Me horny
Driver's side door lock coming out DR.billZ The New Beetle Experience 9 10-12-2009 03:51 PM
WTB: Driver's side mirror part. Dauzh Market Place Archives 2 03-26-2007 12:23 AM
Problem with wiring left side door (central locking + mirror) perso Questions, Issues, Concerns, or Problems with the New Beetle 0 06-03-2006 01:18 PM
Unknown problem under driver's side front wheel.. help! pinktimbs 2.0 Liter Gas 7 04-04-2006 11:11 PM
Black rubber in driver's side door frame CoriBug Questions, Issues, Concerns, or Problems with the New Beetle 2 01-04-2006 02:34 AM
