I have a V.A.G. code 16705 and 16706, SAE P-code P0321 and P0322 on my 2002 Turbo Beetle. The Bentley book gives the description Ign./Distributor Eng. Speed Inp. Circ Range/Performance for code 16705 and Ign./Distributor Eng. Speed Inp. Circ No Signal for code 16706. What should I look to replace. At first I thought is was crankshaft positioning sensor, but I see that there is a code for that. I purchased a cranshaft positioning sensor but I have not installed it yet.
The problem is intermittent and the car will shut off at a stop and then cranks quite a while until it starts. Every once in a while I will also get an intermittent miss while driving. Any thoughts would be appreciated. |
My experience has been with Holden Commodore Crank Angle Sensors (same as CPS) and your description mirrors those when they fail. They will fail when the engine is hot and a quick test is to pour some cold water over the sensor when it fails. This rapidly cools the sensor and restores it to working condition. On Commodores a faulty CAS does not always log a fault. Good Luck.
| need help with codes | bobaganoosh | 1.8 Liter Turbo | 6 | 12-30-2006 04:50 AM |
| Getting some diagnostic codes | vwvari | 2.0 Liter Gas | 2 | 04-20-2006 04:47 PM |
| Diagnostic | arrival | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 04-05-2006 12:36 PM |
| Tranmission Codes | VW2.0Driver | Transmission Talk | 1 | 04-04-2006 10:43 PM |
| e-codes | tjd | Technical Modifications | 0 | 01-20-2006 10:30 PM |
