'02 Beelte GLS - Major Engine Problem! - NewBeetle.org Forums
Old 03-04-2007, 08:32 PM
Exclamation '02 Beelte GLS - Major Engine Problem!
Every now and then the car has these sort of "hiccups", where I feel the fuel isn't getting to the motor sufficiently and the car begins to have spurts of speed and then will cut off and then on again. At the beginning, the motor would just shut off and as soon as I would turn it back on it would be fine, but now its getting out of control; I'll be driving and all of a sudden it will feel like some one pinched the fuel line and I will instantly loose 10 MPH and then it will go back and forth. I notice this happens usually when I have the AC on (set to a low or 1). I have taken it to 2 different VW dealerships and they have both said the same thing, and have found nothing wrong with the car. I am going crazy because no one can tell me what the hell it is or what the F$#% I should do. I hope someone could help me in this matter, PLEASE.
Cheers,
Bico
P.S. Nothing has been done to the car, and has all of its stock parts. It currently has about 16,000 miles.
Old 03-04-2007, 08:53 PM
ristinkay's Avatar
ristinkay
Cranbrook, BC, Canada
Car: New Beetle 2001 1.9 TDI Silver Arrow Mettalic
know what I dont know but try and take it to a different shop, make sure they know a lil about vws though
Diesel Fumes make Me horny
Old 03-04-2007, 09:23 PM
wasting my time in Cancun
Cancun, Quintana Roo, Mexico
Car: 2003 New Beetle GLS 2.0 Stick
but hes saying he took the car to a VW dealer so they must know about VW's...
I kindda feel the same think on mine when a shift a lost kindda power mine its a GLS stick 2003 and a use a lot of gasoline! 160 miles per a full tank
Old 03-05-2007, 12:14 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Cheers,
Bico
Don't worry. Hopefully someone who is far more knowledgeable about computer controlled engines than me will weigh in and give you some ideas but if not, I am sure it will eventually throw a code, then the dealer or a good shop can figure it out. That is the problem with today's complicated engines. In the old days, engines were easy to diagnose but those days are long gone. A clogged fuel filter would have been the first thing to check on an old engine, but at 16,000 miles there is very little chance that is the problem.
Old 03-05-2007, 04:37 PM
Default Thank you
very good posts so far
Thank you very much. As soon as I know what the problem is, I am posting it here!! In the mean time, its just the waiting game.
Old 03-05-2007, 05:08 PM
noR's Avatar
Administrator
Jackson, MS, USA
Best chance I think you have is finding a way to 100% reproduce the problem. Then take a mechanic on a ride w/a laptop/vagcom 1552/whatever. It's likely some controller flippin' out, thinking it's acting right (so it doesn't cause an error code) but ultimately not.
noR | me | Phrog
PHROG
Old 03-05-2007, 05:11 PM
Car: 1998 2.0L 5 spd
clean or replace the maf sensor
"There is no TEAM in I
Old 03-05-2007, 07:43 PM
JetPuf's Avatar
Wee more cowbell
Troutdale, OR, USA
Car: '98 GLS TDI 5sp
16k is early for a fuel filter, but if you got a bad tank somwere it could be toast. probably not to expensive to change out in a gasser.
White '98 NB TDI "JetPuf" 245k
All the fixins'
Old 03-06-2007, 12:18 AM
KK BUG's Avatar
Tempe, AZ,
Car: 2001 Cyber Green GLS "Gertie"
It sounds just like a problem I had with my '96 Golf. It would drive very erratic sometimes, wouldn't respond to the throttle and sometimes it would just die all together; it turned out to be a bad fuel pump. I'm still learning about the NB so I'm not sure if this is a possible problem but it's probably worth looking into. Good luck!
My Webpage
My Gertie
Old 03-21-2007, 11:43 PM
Unhappy Found Problem!!!
Appearantly when I bought the auto, there glorious 101 point inspection overlooked the fact that the fuel pump had been corroding while in the lot waiting for purchase. So the sediment from the filter was making its way into the fuel line thus causing the malfunction. Hope by posting this someone will benefit from it. Thank you to all!!
2002 GLS 2.0L engine codes AVH & AZG Skoobahead 2.0 Liter Gas 2 01-22-2011 02:09 PM
New to Forum and engine/cooling/heater problem sctthrtr 2.5 Liter Gas 38 04-03-2007 05:40 PM
Noisy Engine Problem. Help! v132z 2.0 Liter Gas 5 11-14-2006 01:15 AM
1998 new beelte not running right baddassbug 2.0 Liter Gas 13 03-20-2006 11:24 PM
Strange problem/check engine light silverpodgirl The New Beetle Experience 11 01-06-2006 10:07 PM
