How to change bulb inside bottom of doors? - NewBeetle.org Forums
Old 03-19-2007, 04:23 AM
Mancos, CO, USA
Car: 2000 2.0L Techno-blue
Arrow How to change bulb inside bottom of doors?
Can anyone tell me how to remove the red plastic lens and change the bulb at the base of the passenger door? Mine has burned out...thanks!
Old 03-19-2007, 04:55 AM
Breez's Avatar
Life is good.
Phoenix, Arizona, USA
Car: "BB" a 2001.5 New Beetle 2.0L GLS in Techno Blue
Are you sure its burnt out??? make sure its the bulb and not the sensor...
... is your door still chiming when you open it and leave the keys in, or the headlamps on??? If you still get your "chime" then its the bulb... if you have lost the chime.. then its the sensor.
My drivers side door doesnt work and its the door sensor... which the dealership wants an arm and a leg for
Hope that helps.
Change brake light bulb redbug119 2.0 Liter Gas 8 03-12-2012 02:12 AM
Speedo bulb change JohnnyJet Technical Modifications 5 12-24-2006 02:45 PM
HOw do I change my high beam bulb? chaddicus Technical Modifications 2 08-15-2006 05:05 PM
how to change headlight bulb on 2006M/Y? tomshimizu New Member Forum 1 03-26-2006 01:43 AM
Change Headlight Bulb kiltedbeetle 1.8 Liter Turbo 6 10-13-2005 04:29 PM
