Electrical Gremlins - Headlight and Radiator Fan - NewBeetle.org Forums
Old 03-22-2007, 08:18 PM
Darkstar's Avatar
Mountain House, CA, USA
Car: 1999 1.8T
Default Electrical Gremlins - Headlight and Radiator Fan
Okay the electrical gremlins have raised their green warty fingers and cursed my car (99 1.8t) in the last few weeks...
Driver's side headlight stopped working: I replaced the bulb, and checked the fuses, and it still will not light up.
Radiator Fan: Under the dash on the drivers side I heard this strange sound of electricity arching, kind of like the sound of a hard drive on a computer working, and the radiator fan turned off and on along with the sound. Now, the fan runs almost constantly.
Drivers side door lock: When arming the alarm, the drivers side door will not lock the first time (passenger side works fine). The only way to make the driver's side work is press the unlock button, then the lock button.
Shocking: When getting out of the car I frequently get static shock. I dont know if it's just my uniform causing static or if there is a bad connection somewhere.
Any help is greatly appreciated....The dealer is going to rape me to fix all of these.
Old 03-23-2007, 04:25 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
For the headlight, check the ground connection. Better yet, check the connector that goes to the base of the lamp.
The sound from under the dash most likely is a relay.
The door issue might be the micro switch inside the door.
For the static, try using an anti-static fabric spray on the seat cushions.
Old 03-23-2007, 06:03 AM
Darkstar's Avatar
Car: 1999 1.8T
Great! Thanks! I'll check it out tomorrow...
just replaced the radiator in my nb jazzcat 2.0 Liter Gas 3 10-02-2007 06:12 PM
WTB NB radiator PunkinBug Market Place Archives 0 11-18-2006 04:27 PM
'06 radiator fan questions.... Grover 1.9 Liter TDI 10 08-07-2006 05:03 PM
Radiator Fan and O2 sensor Smileybug 2.0 Liter Gas 2 06-06-2006 06:34 PM
Temp Light Gremlins?? VDUBYA Questions, Issues, Concerns, or Problems with the New Beetle 8 11-21-2005 11:56 AM
