Remote Battery Life..how long? A poll! - NewBeetle.org Forums
View Poll Results: How long has your remnote battery lasted?
More than 5 years 22 48.89%
3-5 years 14 31.11%
less than 2 years 8 17.78%
don't have a remote ( so why did you even answer 1 2.22%
Voters: 45. You may not vote on this poll
Old 03-29-2007, 02:29 PM
boblamb58's Avatar
Send Money
Levittown, PA, USA
Car: 2008 Scion xB 5-speed manual in Nautical Blue Metallic, 1999 Honda Shadow 750 ACE Deluxe
Default Remote Battery Life..how long? A poll!
Just wondering.. seeing as how the "How do I replace the battery in my remote?" question pops up on here about once a month... how long should one expect the battery in the remote to last?
I am 6 years and 2 months into the first battery.
I have been using just the one remote (I got 2 when I bought the car new) and at one point a few years ago I thought it needed a new battery. I took it apart and as I was pressing on it it was making my car doors unlock and lock.(I was sitting in a chair inside my house. Outside the window next to me was my car, so I was only about 10 feet away from it) I put it back together without changing the battery and have been using it since.
So how long did (has) your battery last(ed)?
Do you use only 1 remote, or do you switch from time to time?
Television is more interesting than people. If it were not, we would have people standing in the corners of our rooms. If parents would spend less time worrying about what their kids watch on TV and more time worrying about what's going on in their kids' lives, this world would be a much better place.
Old 03-29-2007, 05:44 PM
Blinky's Avatar
Indianapolis, IN, USA
Car: 2006 VW NB Option1
We have an '06 NB (bought August of 2006) and the remote that my wife uses has had the battery replaced once (by the original dealer) and then the entire keye set was replaced by a diff. dealer. Her fob (remote) kept eating the battery. So far so good.
THe battery which is in the fob is a fairly common battery (2032, I think? (correct me if I'm wrong)) and it should last for, at the very least, 3 years - if not many more. That battery is so common that you will (most likely) find it in your computer (desktop / laptop). How many of you have had to have your computer's CMOS battery / batteries replaced in the past 5 to 6 years?
Old 03-30-2007, 04:18 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
After the battery died a second time, I just use the key now. No big deal.
Old 03-30-2007, 04:32 AM
taterbug's Avatar
Ride it like you stole it
Fabulous Covina, So. Cal, USA
Car: 2000 Beetle 2.slo GL
Got 6 years on the first one... Now using the second one that came with the car. If you need it changed cheap a friend went to an alarm shop and they changed it I think just for the cost of the battery.
Dream as if you'll live forever.... Live as if you'll die today. -- James Dean
Old 03-30-2007, 05:33 AM
sb_beetle's Avatar
CA, USA
Car: 2004 NBC 1.8T
Thumbs up Just replaced
I just replaced the battery in my remote 2 weeks ago (purchased Sept. 2003)
SoCalnewbeetleclub
Old 03-30-2007, 01:39 PM
This is actually a really good question...I don't know if the battery in mine was ever replaced. I've had my car for almost 2 years and haven't replaced it yet. Been wondering what I should be expecting on it. I know I don't have a good range on it though so maybe its dying a little.
Old 04-05-2007, 04:00 AM
chelsie's Avatar
IL,
Car: 2001 Techno Blue GLS | 2005 Corvette Z51
Got my 01 on May 23rd 2001 and replaced the battery just after Christmas 06. I'm impressed!
Old 04-05-2007, 02:28 PM
Car: 1998 2.0L 5 spd
I have never changed the battery in the remote since new (1998), I use it all the time. I can honestly say I have never put the key in the door or hatch.
"There is no TEAM in I
Old 04-25-2007, 04:38 AM
ney-ho-ma? (how are you?)
Colorado Springs, CO, USA
Car: 03 convertable
Default Remote lock key battery
The battery on my wife's FOB key just died but mine is ok. It was just dead (no red blink at the key when the unlock or lock buttons pushed.
I usually keep the quarter size battery 3volt CR3032, (I believe), in the fridge because the garage door opener, the FOB key, Casio watch and my computer memory all use the same battery. Don't take the key apart if you do not have a battery ready to replace it. It may cause the memory to reset and reander the key needing reprogramming.
The FOB key must be split into three parts; the flip-key can be seperated in half (from key loop to key) with a small flat blade screwdriver. Then the button half must be split in half again along the side seam. The battery + is marked on the half that holds the battery so it's pretty hard to get the battery in wrong.
Rocky Mountain Hi_gh
Old 05-08-2007, 04:59 PM
boblamb58's Avatar
Send Money
Levittown, PA, USA
Mine is still going, I occasionally use the key in the lock (less than once a month). When I took mine apart, I did remove the battery, but I did not need to reprogram the romote.
Old 05-08-2007, 08:59 PM
TDI-Sport's Avatar
Rockin' the Suburbs
West Chester, PA, USA
Car: 99 GLS TDI
8 years 16 days. I've had a remote window controller installed for several years so the remote gets above average use.
Cleopatra - 1999 TDiMBCC Interior, KYB AGX Shocks, Eibach Springs, VR6 Clutch, Bosio PowerPlus 520 Injectors, 110 hp, 180 ft-lbs
280,000 Miles13 Years0 Regrets
Old 05-09-2007, 05:44 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I got a new remote after the car was 4 years old .... but it was still working, not looking good though, have had the replacement 2.5 years at least, no problems, and I am sure the original one still works also.
Old 05-10-2007, 06:56 PM
imsos04's Avatar
04 NBC Turbo Tiptronic
Richmond, VA, USA
Car: 04 NBC Turbo Sundown Orange
Well, my car just hit 3 years old and battery still goin' strong!
Old 06-15-2007, 01:25 AM
I have 6 years on Beetle remote. My Jetta lasted only 2 years
Old 06-15-2007, 07:08 PM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
Since there wasn't an option for 2-3 years, I marked 3-5 years since I've had my Beetle closer to 3 years than 2. I only use 1 fob and it's still going strong after 2 years, 7 months.
Cori
Transmission Life, How Long Till She Blows? K-BL New Member Forum 9 02-25-2007 09:52 PM
XM vs Sirius Poll SPIRU Miscellaneous Hoo-Ha Archive 133 11-03-2006 11:53 PM
Remote Entry Battery CYBERGREENCC Questions, Issues, Concerns, or Problems with the New Beetle 1 07-04-2006 07:24 PM
Oil Poll Beetlebomb 2.0 Liter Gas 26 10-21-2005 02:39 AM
Remote battery replacement astroclimb Questions, Issues, Concerns, or Problems with the New Beetle 4 10-19-2005 05:10 PM
