My car had the exact same issue. At first I thought maybe I was hitting the gas by accident but I would make sure my foot was far from the gas when I started the car and it would still do it. It wasn't all the time but it did it enough that I thought something was up. It got to about 2000 rpms and then dropped, just as yours is doing.
What fixed mine: replacing the coolant temperature sensor. I threw a code on that and my bf did some reading up on it. Apparently because it deals with the temp of your coolant, it will rev the engine if it thinks its too cold. I put a new sensor in it, no problems since.
I didn't mean to say O2 sensor in my initial post. I actually did mean the coolant temp sensor - and I just realized it after reading your post. Sorry for my lameness ... heh.
Guess I cannot think straight. My fiance said that maybe it is a vacuum hose leak? I am having a loss of power at times around 3,000 RPM in second gear ... which is sad since that is my favorite gear. It kinda bogs down like I let off the gas and then hit it again. I had my boost read and they said it was normal. |
Third gear is my new favorite .... 2nd was before chip.
No sounds of boost loss? Check that the temp sensor is plugged in all the way, heck check that all of them are plugged in all the way, plugs and MAF also. Also check your Diverter Valve, probably about time for the OEM one to give out. The springs get weaker and let boost bypass them. I have not experienced what you are, but I have been having a VAC leak for 2 weeks now, 12in instead of 22in, and yesterday was the first time I really had a chance to get on it, still feels the same, but couldn't get more than 10PSI on the Gauge, usually spiked at 21-22PSI. On the plus side, I seem to be getting a little better MPG. |
I would imaging a vacuum leak isn't fun. Bleh.
I believe my Diverter Valve was replaced by the dealer about 2 years ago ... for weird fluttering. That and the BOV. Zoomer didn't do this today. But ... I will let ya know when it does it again. BTW - something Ive been meaning to ask but didn't want to start a new thread for something so ... silly. If the car isn't showing a CEL (or any other light) ... does it still carry codes? If I were to vag-com the car even though there arent any CEL's ... would it have codes if there were any? See ... silly isn't it? ![]() |
| Engine takes a few too many turns to start.... | Shamrockez | 1.9 Liter TDI | 22 | 03-09-2007 07:09 PM |
| Flashing Red Engine Temp on Start-up | bub | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 11-05-2006 12:46 AM |
| Didn't use my nb for 2 months and engine doesn't start | limmy | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 08-14-2006 01:32 PM |
| **** Noise from engine at start-up ***** | big3.mango | Questions, Issues, Concerns, or Problems with the New Beetle | 12 | 08-03-2006 02:39 AM |
| When you first start your engine . . . . | EvilinaDM101 | 2.0 Liter Gas | 21 | 04-12-2006 09:57 PM |
