trunk won't open - NewBeetle.org Forums
Old 05-27-2007, 08:11 AM
Denham Springs, LA, USA
Car: 2000 NB 1.8t
Default trunk won't open
Originally Posted by XCman
If you push the button on your key to open your trunk and you get a "click-click-click" noise before the trunk opens or no response at all. You are prolley looking at replacing the rear hatch actuator.
Does this also apply if you press the button on the door, you hear the actuator working, then you have about 1.5 seconds to run to the back and pull it open before it grabs hold again? Or is there some adjustment that can be made so it waits a little longer? My wife can't move that fast!
Old 05-27-2007, 07:04 PM
phantom302's Avatar
phantom302
Laramie, WY, USA
Car: 2003 GL
Madwand, My car had the problem you are describing when I got her. My dealer installed a stronger spring in the truck latch and now I have no problems, even after installing a spoiler. IIRC the spring they used was from a Jetta hood latch. Hope this helps.
Old 05-28-2007, 05:20 AM
Car: 2000 NB 1.8t
Mine has a big spoiler on it, I guess that could be the reason, extra weight not compensated for by the OEM spring!
Old 05-28-2007, 06:41 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Use a T-30 TORX driver and loosen those black rubber blocks located just below where the strut meets the body. Move those blocks away from the body a little and see if that gives the trunk lid enough push to get past the re-latching mechanism...
Trunk wont open Stl5152733 Technical Modifications 2 01-06-2007 11:31 PM
Trunk Won't Open justaguy Questions, Issues, Concerns, or Problems with the New Beetle 2 12-24-2006 04:11 PM
trunk/hatch won't open all the way by remote AmazinglySmooth Questions, Issues, Concerns, or Problems with the New Beetle 11 10-31-2006 02:34 PM
Open? LunaFaye Questions, Issues, Concerns, or Problems with the New Beetle 2 10-14-2006 02:17 AM
Help !! Can't open trunk Naen 1.8 Liter Turbo 1 06-06-2006 03:50 PM
