P0133 & P1196 codes Need advice!!! - NewBeetle.org Forums
Old 07-06-2007, 12:38 AM
speedsk8er's Avatar
SMOKEN KO4
Default P0133 & P1196 codes Need advice!!!
The other day my car started to stall out at a stand still... The check engine ICON came on and set off a P0133 Oxygen sensor circuit slow response ( pre- converter sensor) and P1196 code Oxygen sensor heater electrical malfuction ( pre-convertor sensor) OK. so I repaced the pre- convertor O2 sensor and reset the car... I took it for a test drive and the car set off another check engine light. This time just the P1196 code, Heater electrical malfuction pre- convertor. And the car is trying to stall out again. If I reset? It comes back again P1196 code. What can I do to fix this code issue?!?! Or could it be, a BAD O2 sensor??? Thanks in advance for the help. My car is up 4 sale and this is the only issue I have with it............."HAPPY 4TH of JULY".........
Sk8er
Modified KO4 Powered
Old 07-06-2007, 01:15 AM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
Could be a bad heating element in the new O2 sensor ... but first check your wiring, make sure none of the wires in that harness are broken or grounding out.
2002 GLS 2.0L engine codes AVH & AZG Skoobahead 2.0 Liter Gas 2 01-22-2011 02:09 PM
Codes funky 1.8 Liter Turbo 7 07-08-2007 12:02 AM
E-codes JetPuf Technical Modifications 5 03-07-2007 05:47 PM
P0102 & P0112 codes, and other questions Gotlift02 2.0 Liter Gas 2 01-18-2007 06:42 PM
need help with codes bobaganoosh 1.8 Liter Turbo 6 12-30-2006 04:50 AM
