I've been using Castrol Full Syntetic since i've had 'Cup and that's been since April '01
Here's the deal, as embarassing as it is. I just got the car a few days ago. I stopped by Walmart today and had the oil changed with mobil 1. I had glanced at the owners manual a few days ago, and swore it said 10-w-30. I had them do it. Shortly after getting out of Walmart, I second guessed myself, and checked out the manual again. Ooops! I'd have bet $100 on it too, I was so sure. So, what's the verdict? Any VW mechanics out there that can answer for certain? Thanks again!
Sincerely, Stupid. |
The 10W-30 full synthetic works fine due to it's superior circulatory charactoristics over organic oils, however, I would suggest staying with the factory recommended 5W-30 oil.
Unless you live in a geographical area that is very cold, zero weight oils are not necessary nor are they recommended. The brand of oil used is up to each individual, I only use Redline or Royal Purple full synthetic in my personal car engines.
Youth ages, immaturity is out grown, ignorance can be educated and drunkenness sobered.....But stupid, lasts forever. Last edited by Too Cold NB1.8T; 07-17-2007 at 04:07 PM.. |
Royal Purple is a very good engine oil, some would say that Redline and Royal Purple are not as easy to find like some other oils mentioned, remedy: Buy/order a case or two at a time from a local store or order it online and replinish your supply as needed, this way you never run out and you don't have to go searching for it everytime you need to change your oil.
I mostly use Redline and I've used it for a great number of years in multiple vehicle engines but I have logged a lot of miles with Royal Purple and at this point, I personally would not use any synthetic oil other than the two I mentioned above. |
| Oil leak after 1rst oil change. | shafrs3 | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 04-09-2011 09:04 PM |
| Oil, oil additives, and fuel additives. | sidaust | Technical Modifications | 15 | 07-22-2008 01:22 AM |
| FS - NB TDI bottom engine cover parts, oil filters | dxrobertson | Market Place Archives | 3 | 06-15-2007 08:31 PM |
| Engine using oil | sailforth | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 05-10-2007 05:33 AM |
| New oil for PD | MAd_Matt | 1.9 Liter TDI | 15 | 02-08-2006 05:23 PM |
