"BRAKE" light blinking on dashboard panel - NewBeetle.org Forums
Old 07-15-2007, 03:28 AM
Default "BRAKE" light blinking on dashboard panel
Hi everybody.
Since this past Thursday, the "BRAKE" indicator blinks for three or four times with a beep on the dashboard after a minute or two of driving. What would be the cause? I had the brake fluid replaced about three months and 6000 mi ago. Maybe the brake pads? About a year ago I had them inspected, and they said they would last two or three years from then...
Thanks!
Julian.
Old 07-15-2007, 03:38 AM
who_me285's Avatar
Austin, TX,
Car: 2002 GLX 1.8t
Hiya! Welcome to the org! hmm brake light eh? So is it the one that says "brake" or the one that shows the brake pads. If it is in deed the "brake" light, the most common thing is the e-brake is on slightly. I think if there is a prob with the abs that will light up too, not sure on that thoguh without getting my book. if it is the circularr light that has little lines around it then it is your brake pads wearing out. ooh also lets see some pics of your beets!
[SIZE="2"][B]Bailey - My Beetle!
Old 07-15-2007, 04:15 AM
Nah the ABS system has it's own light.
I would say get the master cylinder checked and make sure it's full of brake fluid. Or, it could be the actual e-brake sensor that tells you when the e-brake is up.
Good luck!
SMG
Old 07-15-2007, 04:43 AM
niki's Avatar
#1 Auntie
CA, USA
Car: Former owner of Bugzzi ('99 White GLS), new owner of '10 Civic LX-S
This has happened to me twice now. When mine does it, it's only when I come to a complete stop. It beeps 3 times then the light blinks away. And my e-brake isn't on. If I turn the car off it goes away.
I figured it was a weird wire or some quirk. I'm curious to see some answers in this thread.
If you ask for more patience do you think you'll simply get more patience?
No. You'll get an opportunity to be patient.
Old 07-15-2007, 05:41 AM
dasmurph's Avatar
Portland, OR, USA
Car: 2003 Jetta GL 2.0
It must be a glitch because the "BRAKE" light and a tone means your e-brake is on. Either you have a really stiff e brake lever that's not being pushed down far enough to please the sensor or there's some sort of malfunction, no biggie, just an annoyance.
Old 07-31-2007, 04:00 PM
niki's Avatar
#1 Auntie
CA, USA
Hey fyzixx... ever find anything out about this? Mine's startin to bug... it's doing it more often.. Sometimes it'll do it everytime I step on the brake and when you're in stop-and-go traffic it kills me...
Old 09-06-2007, 06:11 PM
fulltiltredhead's Avatar
Alexandria , VA, USA
Car: 2002 Color Concept Yellow 1.8T
Default Brake Fluid!
Check your brake fluid. I had the same experience just recently. I thought it could not be brake fluid because I had just had the oil changed at Jiffy Lube and they are supposed to top off your fluids. I checked the brake fluid and it was quite low. I filled it up and the light stopped flashing and chiming.
Check your brake fluid even if you don't think that's what it is.
Old 02-05-2012, 05:00 PM
Correct! I had the same problem and checked brake fluid level. Emptied one bottle of brake fluid so it means brake fluid is low.
Old 02-05-2012, 05:10 PM
IndyTom's Avatar
Indianapolis, IN, USA
Congrats on resurrecting a 5 year old thread
If you had to put a whole bottle of brake fluid in your resevoir then you have a problem. Check for leaks. Something definitely isn't right.
Old 02-05-2012, 05:21 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
What Tom said. A whole bottle means you gotta problem in the brake or clutch system.
Peace Love an T.o.D.
Old 02-06-2012, 12:34 AM
Bratgirl's Avatar
Powered By Pixie Dust
Riverton, UT, USA
Car: 2002 Yellow GLS
Noticed this a lot lately. Obviously they do not look at the dates??
Live a Life of Serenity, Not a Life of Regret.
Current NB 2002 GLS Double Yellow "Pixie"
Previous NB 2000 GLX Black "Little Ed"
"Other" Road Trippin' Ride
2010 Dodge Challenger Bright White "Baby"
Help! brake light blinking on and off 1.8tbluebug1984 Questions, Issues, Concerns, or Problems with the New Beetle 3 08-26-2007 02:38 AM
Where Can I Find "Green Stuff" Brake Pads??? scarabY2k Market Place Archives 13 07-16-2006 08:13 PM
Clear brake light for "no-drill" style spoiler Skweeker Styling Modifications 5 05-23-2006 11:10 PM
ABS and Brake light blinking/beeping Javaholic 2.0 Liter Gas 13 04-18-2006 02:22 PM
