Rear view mirror buzzes - NewBeetle.org Forums
Old 07-18-2007, 04:54 AM
Talking Rear view mirror buzzes
The rear view mirror on my 04 Beetle buzzes annoyingly from road vibration at 25-40mph give or take. I've tried all sorts of solutions without much success.
Any suggestions?
Old 07-18-2007, 12:34 PM
member
Toowoomba, South-East Queensland, Australia
Car: 2005 1.6l automatic sunflower
If its the glass vibrating within the plastic outer shell then I'd stick some Blu-Tak on one edge between the glass and the plastic to dampen the vibrations. If Blu-Tak isn't sold in your country then chewing gum should do.
If it's the whole mirror and plastic outer shell thats vibrating (which it shouldn't) then try wrapping something solid and heavy around the post that attaches the mirror to the roof - maybe wire solder, copper wire or something to wrap around the post - this will dampen the vibrations.
Good Luck.
Old 07-18-2007, 01:32 PM
GINA's Avatar
Custom User Title, go!
Baltimore, MD, USA
Car: 2008.5 Mazdaspeed3
Mine does this too! I was starting to think I was the only one with this problem. I figured out that it's the light underneath the mirror. When I touch it and give it pressure, it stops the noise. I haven't tried anything yet, but maybe just putting a piece of tape would help? Let me know if you figure something out.
Old 07-19-2007, 03:29 AM
Same here.Seems to be my light switch as well.
Old 07-19-2007, 11:03 AM
member
Clear tape sounds like a very simple answer.
inside rear view mirror - how to remove Batguano New Beetle Convertible 8 05-14-2008 09:59 PM
What's hanging from your rear view mirror? Maggadog Miscellaneous Hoo-Ha Archive 99 11-28-2007 02:04 AM
red LED lights in the rear view mirror PacoBofarull Styling Modifications 4 03-02-2007 08:52 AM
How do you replace pass side rear view mirror glass? loseph Technical Modifications 1 10-22-2006 02:45 PM
anywhere else to get the bugsagogo rear view mirror? ninsei Styling Modifications 8 11-23-2005 01:36 PM
