2001 NB with Non-Monsoon 6-speaker radio/cassette HU.
Been suffering a battery drain for over a year now but was lazy about it (battery drains in 3 days, so being a daily driver it basically was a "non-issue"). I finally sat down and started pulling fuses and found the drain was eliminated (a whopping 0.60 A dropped to the nominal 0.04 A) when I pulled fuse 42. Forums browsing reveals this is the radio, but all problems were related to a non-working Monsoon system that needed resetting by pulling the fuse. None were about a parasitic battery drain on a non-Monsoon system. Anyhow, what now? Do I pull the HU and try pulling its fuse? I noticed one the other day when I was replacing my center console trim piece (that sucked, by the way, how many screws do you need for a trim piece?!) and had to pull the radio. What could cause the radio system to drain the battery (it's not on or anything... though the little blinking red light is there when the car is locked)?
2001.5 NB GLX AWV 02J LG5T 08H/ZD, with modifications Last edited by paultakeda; 09-16-2007 at 07:06 PM.. |
It's possible the radio isn't shutting down properly when you turn the ignition off.
Search for "drain" on this page http://www.carsurvey.org/viewmorecom...w_51763_3.html Hope this helps. |
Do I need a new HU? Is it just the wiring harnesses (a crossed wire, for instance)? |
Well, it's the original radio and original harness, not sure how it could get mixed up.
There have been no electronic problems detected. All I have is the battery drain, which is not drastic but does drain the battery enough in three days to prevent it from cranking the engine. Some reports have the radio staying on, but the drain would be overnight. This is not the case with mine. There's a drain, but it's not enough to drain overnight, something I haven't found to be a problem reported by others in various forums. |
Well unplug your radio, via fuse or harness, doesn't matter. If the draining problem stops, then that's the culprit. Get a new headunit. All this speculation without action ain't gonna give you any answers. I'm sure you can live without tunes for 3 days.
You come on here for suggestions, you get free advice. If you don't like it, go pay some "expert" to diagnose it for you. Quote:
I actually posted this issue in another thread but had no response, this one got by me for some reason. I tried swapping the HU with another and even changed out the amp...still have the 2amp drain with fuse #42 in. I am stumped.
![]() Please help. |
I looked up the radio wire diagram and there is another connection that comes off of fuse 42 besides the radio; it feeds instrument cluster. There also appears to be an antenna amplifier; if I was going to look for something shorting out the radio the antenna would be at the top of my list.
Also fuse 37 (ignition switch) is connected to the radio, which also feeds the instrument cluster and some control module; unfortunately the radio diagram was not specific, I'll have to pull the instrument cluster diagram to get more info. Last edited by D2Beetle; 10-13-2008 at 01:05 PM.. |
My battery drains too, and in vag com my antenna is shorted (run the radio and instrument cluster diag) I havent had time to fix it but I KNOW is the darn antenna short.
Bugs dont Leak! they are marking their territory!
223 Hp says the dino..but traffic says 15 mph DARN.... Can you get me one of those empty highways that appear on T.V. Car commercials? |
In short there is a spring loaded switch in the ignition switch that is turning more than just the radio off. |
| Battery discharge or drain problem | RobertH | Questions, Issues, Concerns, or Problems with the New Beetle | 17 | 08-22-2011 08:14 PM |
| Anyway to cut turn something on to drain the battery | fatdaddy | Technical Modifications | 9 | 11-23-2009 09:38 PM |
| New fuse block above battery | cyberbeetle | Market Place Archives | 11 | 11-12-2007 05:38 PM |
| Need Help with Battery Drain / 2000 1.8 | Googan | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 06-27-2007 05:15 AM |
| Can someone make battery drain when parked? | fatdaddy | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 02-22-2006 02:02 AM |
