Temperature Light - NewBeetle.org Forums
Old 11-11-2007, 09:07 PM
Default Temperature Light
I drive a 1999 Beetle. My temperature light came on, flashed and beeped at me and then went off several times in a day about a month ago. I added coolant and everything seemed to be fine until yesterday. The light flashed and beeped and then went off when I first got in the car and then several more times throughout the day. From what I understand this means that I probably have some sort of leak? Is this right? I just wanted to ask for advice before I take it in and sound like an idiot girl when I try to explain my problem... Thanks!
Old 11-11-2007, 09:45 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
Just so you know, continuing to drive while the red light's flashing at you is asking for engine damage Could be just a leak, but could be the water pump. The sooner you check it, the less additional damage you're likely to cause.
Here's a look at Ladybug
Old 11-11-2007, 10:49 PM
Thanks! I was plannng to have it checked as soon as possible and I don't intend to drive it until I am able to get it checked because I was aware that it would likely cause additional trouble. I just couldn't take it in today and was curious as to the possibilities.
Old 11-12-2007, 01:11 AM
Turbo S: Who needs mods??
USA
Car: 2002 Platinum Gray Turbo S
I say your waterpump failed. The impeller is made of plastic and it tends to disintegrate over the years. It either breaks into pieces or it no longer is attached to the pump shaft. It's internal so you won't be able to tell just by looking at it nor would you necessarily see a leak. There's nothing left of the impeller to circulate the coolant, thus the temperature warning light coming on. Given the age of your car, I'm almost positive that's the problem. If the timing belt hasn't been changed within the last 60K miles, you may as well it replaced since that needs to be removed to get at the pump. Good luck.
Old 11-12-2007, 01:36 AM
About how much will a water pump cost me if that is the case?
Old 11-12-2007, 01:45 AM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
In my case, it was only a sensor. Good luck to you.
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
temperature not showing/ light not working blue_bug Questions, Issues, Concerns, or Problems with the New Beetle 7 01-24-2008 06:35 PM
red flashing temperature light shellbug Questions, Issues, Concerns, or Problems with the New Beetle 11 12-04-2007 07:43 PM
Red Flashing Temperature Light Trbowgn 1.8 Liter Turbo 5 09-26-2006 08:46 PM
flashing temperature light at start up? mike 51 1.9 Liter TDI 2 08-21-2006 02:16 PM
blue temperature light starinureye 1.8 Liter Turbo 4 01-03-2006 07:19 PM
