Brake Fluid - NewBeetle.org Forums
Old 12-06-2007, 11:45 PM
Default Brake Fluid
hey people i have to top up my brake fluid, where and how do i get to it????
Old 12-07-2007, 12:40 PM
Default brake fluid
no one knows how to top up their brake fluid????
Old 12-07-2007, 01:46 PM
Wheaton, IL,
Car: 04 TDI PD
In the engine compartment, under the driver's side windshield wiper.
Old 12-07-2007, 02:31 PM
noR's Avatar
noRRegistered Member noR is offline
Jackson, MS, USA
It's got a yellow cap.
But you shouldn't top it up; you should flush the system, and you should bleed all 4 corners, and the clutch if you have one.
noR | me | Phrog
PHROG
Old 12-09-2007, 12:09 AM
Default brakes
anyone has any pics of this...how to bleed and fill up the brake fluid
Old 12-10-2007, 01:52 AM
TJ3's Avatar
TJ3Registered Member TJ3 is offline
Nashville, TN, USA
Car: 01 Turbo GLX
Default brake fluid
you are going to use the VW fluid!
I topped mine off, no problems. but check your manual first.
Old 12-17-2007, 03:20 AM
bman's Avatar
Saint Catharines, Ontario, Canada
Car: 2000 GLX
Agreed. Topping it up implies you've got a bottle of it open somewhere for the purpose of "topping it up"... and if you don't, you soon will.
But the problem with this is that brake fluid is hygroscopic - in effect, it absorbs water from the atmosphere. Water in a hydraulic system (especially one as important as your braking system) is a real ugly thing.
Instead of topping up, always buy a new container of brake fluid and flush the whole system properly each time you need to (or every two years, whichever comes first.) You then discard the remaining unused (new) and old brake fluid at your local recyclers or hazardous waste facility.
Keeping your brake system clean (with new fluid properly flushed each time) will reward your ownership with fewer brake system repairs or perhaps failures.
Old 04-16-2008, 05:34 AM
1) Is there a specific type of brake fluid that Beetles require?
2) Can someone who has never done this before do it?
3) How does one "bleed" all four corners?
4) How costly is this to do at a mechanic's?
5) Where does one go to get proper brake fluid?
Old 04-16-2008, 11:52 AM
Growler's Avatar
strange things are afoot
Columbus,, OH, USA
proper brake fluid is available at your local auto parts store.
buy yourself 2 litres of the valvoline Dot 3/4 synthetic NOT DOT 5!
there is an excellent how to here posted by myself in a thread started by silverspeedbuggy do a search!
EDIT! found it! http://www.newbeetle.org/forums/show...ht=brake+fluid
You will want to bleed 400ml of fluid from EACH CORNER plus about 300 from the clutch, hence the need for 2 litres of fluid.
depending on what year your car is 2001+ you bleed the fronts first DSF PSF DSR PSR then clutch
older than 2001, you bleed the back first PSR DSR PSF DSF then clutch.
this is because 2001 was a transition year where they changed the ABS pump to a different system and that is what causes the change in the procedure.
if you have a 2001, you need to know what ABS pump you have to determine which procedure to do MK20 or MK60
TDICLUB.com has excellent posts describing the differences visually in the two systems so all you need to do is take a look at the pump to identify it. search for MK20 or MK60 there.
Good luck!
~Aaron~
Old 04-16-2008, 12:10 PM
member
Toowoomba, South-East Queensland, Australia
Car: 2005 1.6l automatic sunflower
The brake fluid is DOT 4 which is much the same as most cars use...but it must be DOT 4. All auto spares shops should carry it.
As to whether you can perform a fluid change yourself is only something you can answer ....but then everyone had to do it the "first time" themselves.
My advice FWIW is to do a bit of research on bleeding/changing the brake fluid. Do this via GOOGLE or at your library or on this forum - that way you will have a pretty good idea of what you are doing and why.
The New Beetle brake system is conventional so there are no special tools needed other than those you would require on a more common car.
In Australia to do a brake fluid change would be about $AUD200 - 300 .
But please don't attempt this if you are unsure - brakes are vital and must always be 100%.
Good Luck.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Brake Fluid Flush / Change - Where is a How-To phoenix_iii 2.0 Liter Gas 19 07-31-2009 11:27 AM
brake fluid draining picked 192 2.0 Liter Gas 2 03-23-2007 01:19 AM
brake fluid type bobbittle Technical Modifications 0 11-02-2006 10:04 PM
How much brake fluid??? SAMPO Questions, Issues, Concerns, or Problems with the New Beetle 5 10-07-2006 11:13 PM
How much brake fluid is in the system of a 1.8?? fohveh Questions, Issues, Concerns, or Problems with the New Beetle 3 10-02-2005 07:14 PM
