Heated Wing Mirror and Lights Warning Buzzer - NewBeetle.org Forums
Old 01-14-2008, 06:12 PM
Red face Heated Wing Mirror and Lights Warning Buzzer
Hi I was wondering if anyone could help me solve two issues with my 2003 New Beetle?
The heated wing mirrors are not working and the warning buzzer for when you have left your lights on has also stopped working.
We have checked the fuses for the mirrors, but they seem fine .... does anyone have any ideas please????
Thank you
H
Old 01-14-2008, 08:59 PM
ubugnme04's Avatar
Proctor, VT, USA
Car: 2004 NB Convertible GLS
The heated mirrors are activated when you turn your mirrow adjustment knob to defrost and turn on your rear defroster. If this doesn't work then they might be "burned" out. If your adjustment knob is left in the defrost position it can burn out the element in the mirror.
Not sure about the buzzer for the lights. Mine doesn't work occaisionally, but I think that it's related more to the issues I have with my drivers side window not dropping and maybe the door not setting off the buzzer...not sure, it doesn't bother me enough to take it to the stealership.
Old 01-14-2008, 09:26 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
The alarm stop working in my '98 because a brown wire had some how been pulled out of the connector under the divers seat. I think one of my kids shoved something under the seat... anyway spliced it back and all is well.
Old 01-15-2008, 08:30 AM
Default Thank you
Hi
Thanks for yoru responses - will see if I have severed the wire and will also see if the mirror defrost works. only had beetle a few weeks and its spent mor etime in the garage than on my drive!
Thanks
H
Old 01-16-2008, 10:34 PM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
The heated mirrors have nothing at all to do with the rear defroster. They run completely independant of the rear (Although I agree that they SHOULD work that way!). If you put the knob in the middle between L and R?....the heaters are on. If you leave them there...they stay on whenever the car is on and they simply burn themselves out. New mirror glass is all it take to fix them...about $30 for each side and 20 minutes to replace.
- Joe
Old 01-18-2008, 11:32 AM
Default Thanks
Thanks Joe
Have decided to send it back to the dealership - I have only had it since August and I have decided it is their problem!
Will report back on what happened
Cheers
H
Old 01-18-2008, 11:56 AM
FlwrPwer's Avatar
Fishkill, NY, USA
Car: '07 Triple White NBC
The newer models have the mirror defrosters go on/off when you put the rear defroster on. There is no other way to use them. The rear defroster also goes off by itself after about 10-15 minutes (I haven't timed it). So they did fix this little glitch, just a little too late.
Old 01-18-2008, 01:48 PM
I stand corrected then...thanks. I guess I should have said that the heated mirrors work independantly from the rear defroster on bugs from 98 thru at least the 2003 model year because those are the only ones I'm sure of.
They SHOULD only work if the rear is on. In fact, they should work like Nissans where there is one defrost button. It works both the rear and side mirrors..ANNNNDDDD...it's on a timer, unlike mine where the switch is either on or off. Thanks again for the info FlwrPwer!
Old 01-18-2008, 01:51 PM
FlwrPwer's Avatar
Fishkill, NY, USA
Yes, that is how my '07 works. I *think* it was changed in '06, but I can't be sure of that.
I know my '04 didn't work like this....
Old 01-18-2008, 10:44 PM
Beetlemania's Avatar
crank it up, suckers!
Broken Arrow, OK, USA
Car: 1999 Silver Aero GL
As for the buzzer, I cracked into my instrument cluster to see if I could replace mine. I think I made mine worse, but I discovered something about the later models. I'd gotten a freebie burned out cluster from my stealership's service department (I know the crew chief) and opened it up. I don't know what year they started, but it had an easily removeable speaker, as opposed to mine which is soldered in. You might be able to get a bad cluster and switch those out!
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings!
Mi Bacca es Chewbacca!
I'm one of those people. Whatever that means.
Old 01-25-2008, 08:25 AM
Talking Problem solved -well almost!
HI Everyone
So the mystery of the lost buzzer and cold wing mirrors is solved - well I hope so!
The garage had the car back and it turns out that the little sensor in the door that tells the computer that you have opened or closed it is faulty! This has stopped the buzzer from dinging as the car doesnt know when I have opened the door!
They are going to replace this under waranty (we hope if the ins co says yes!)
As for the mirrors - it was as suspected, the elements in the mirrors have burnt out( I expect that Lucy the Beetle's previous owner had left the switch on!!!) and I need two new pieces of glass for them to work. Again, they are going to see if this can be done under waranty!
Thanks to everyone for your help - I am now hoping that this is the last of the problems with her and she doenst have to go back in for anything else for a while
Holly
X
Old 01-25-2008, 10:01 PM
Originally Posted by HollyMarie
HI Everyone
Holly
X
You're lucky it's covered under the warranty because VWs don't have the same "little sensor" in the door jamb like most other vehicles. They have to replace the entire door latch with the attached electronics. Glad they found it!
And if they don't cover the mirrors, the glass is only about $30 each and takes less than 10 minutes to do!
Old 01-26-2008, 01:36 AM
Oceanside, CA, USA
Car: 2006 Beetle TDI, DSG, Pkg 1
The owners manual for my '06 says that the mirrors only heat when the rear defroster is on - but it lies!!
Mine work without the defroster being on. Bummer.
Don in Oceanside, CA
2006 New Beetle TDI, DSG, Pkg 1
There's no place like 127.0.0.1
Old 01-26-2008, 03:07 AM
Yours may work that way. Some do and some don't. I know my 01 has nothing to do with the rear defroster. It's easy to test though. Leave the rear def. off and set the side switch in the middle for a few minutes. Then see if the glass is warm to the touch.
Old 01-30-2008, 01:56 AM
Tucson, AZ,
Car: 2001 GLX Silver Arrow
Here's a link to the TDI clubs fix for the door switch if they don't want to replace it under warranty.
http://forums.tdiclub.com/showthread.php?p=730184
Mike
Old 02-05-2008, 10:09 AM
Thanks for the heads up - it is going to cost me £57 in total to get the mirrors done! And the ins said yes to the sensor - thank goodness!
Old 02-05-2008, 10:10 AM
Thank you
H
FS: Heated mirror glass- 6/2000 and later tequilaiam Parts and Accessories 3 08-10-2010 07:27 PM
warning lights on new bug B's Bug New Beetle Convertible 2 05-17-2007 04:07 PM
Lights on dinger/buzzer/alarm thingy no worky! eltonito Questions, Issues, Concerns, or Problems with the New Beetle 9 12-09-2006 02:11 AM
FS: Passenger Heated Mirror and Euro Sw miciam Market Place Archives 0 11-26-2005 11:29 PM
Heated mirror glass, where to buy? jbehm Questions, Issues, Concerns, or Problems with the New Beetle 3 11-15-2005 05:19 PM
