Right headlight bulb - NewBeetle.org Forums
Old 02-01-2008, 11:04 PM
Default Right headlight bulb
How do you replace the right headlight bulb on a 2000 beetle?
Old 02-02-2008, 01:00 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
The following was gleaned (I love that word!) from an entry at Wikipedia's site. I found this to be the simplest interpretation of the process. Enjoy!!!
"The headlight is in a long, plastic tube. There is a slide release on the tube, with a square locking tab right next to it. The locking tab has cross hatches on it. You have to press down on the locking tab, while trying to slide the release toward the fender.
It's usually pretty tough to slide the release, but be patient. If you force it, you could break one or both of the tabs off. This would leave you with no way to remove the headlight.
Once you have released the catches, the entire light fixture slides out of the front of the car. You might want to have someone helping you at this point, as if you drop the headlight you could seriously damage it.
While sliding the headlight forward, detach the power line from it. Do yourself a favor, and spray the cylindrical holder with wd-40. This will make reinsertion much easier."
Old 02-05-2008, 12:29 AM
mrbeetlebrain's Avatar
pixel pusher
Perth, Australia
Car: 2006 MKV GTI
"How To" replace your head light bulbs.
2006 Red MK5 GTI - DSG, Leather, Sunroof, Sat Nav, Xenons || Sold! 2002 Turbo New Beetle
Headlight bulb replacement Buglover Technical Modifications 16 11-03-2006 03:20 PM
What options are there for replacing headlight bulb? jpdeuce Technical Modifications 18 05-09-2006 04:21 PM
changed bulb but headlight still out okiebug Questions, Issues, Concerns, or Problems with the New Beetle 2 05-03-2006 11:28 AM
Change Headlight Bulb kiltedbeetle 1.8 Liter Turbo 6 10-13-2005 05:29 PM
headlight bulb question zenewie Technical Modifications 5 09-29-2005 08:48 PM
