Don't know about the radio draining the battery but DO NOT jump the car with the radio on. It will render it inoperable, calling for a code input; a cruel joke since the code won't revive the radio either.
b |
Well now my car is running fine, but if I turn off my car while the radio is on, later when I start the car the radio tries to read the cassette tape (even though there is no tape inserted) and makes horrible grinding sounds until it displays "Tape Error".
If I turn off the radio before turning off the car, the cassette problem doesn't happen. ![]() |
I've had 'tape error' messages and beeps since I bought my bug, for 3 years now. I'm waiting for the radio to go totally toast before I replace. I suspect something similar's happened to it before it became mine. Good thread.
I have been in and around the forum today and found this thread to be the closet match for my problem.My battery was dieing overnight lately and i did the process of elimination steps with the fuse box and found that with fuse #42 in I have a whooping 2amp drain ! when i pull it the drain goes down blow like 0.03 . That is the radio power and i even tried to switch out the stock HU with another stock one and the problem remained (monsoon BTW and with the fuse in and the HU unplugged-no drain). I read somewhere here that the amp may not be shutting off and I have noticed a "pop" when i turn off the radio like when you turn off your TV before the surround system. Is there a way to check for sure if it's the amp and is there a fix that anyone knows of? Please help me if you can. Thanks in advance. ![]() |
Well I still have the power draw....I installed a 2005 amp(same year as the CD) and I don't have the "pop" but the 2amp drain remains with fuse #42 in. My NB is a 2002
TS and am looking for ideas here. please help.![]() |
| Sunroof drains - a cautionary tale | DriverFound | New Beetle Detailing/Cleaning | 15 | 09-22-2009 10:22 PM |
| Battery drain tied to fuse 42, non-mosson radio works fine | paultakeda | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 10-14-2008 12:35 PM |
| Winterize - Sun Roof Drains | Lugnutx5 | Technical How-To | 4 | 09-26-2006 06:21 PM |
| Aftermarket Radio inop after battery disconnect | 2002bug0220 | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 05-19-2006 05:53 AM |
| Battery Dies | ed hall | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 10-02-2005 12:03 PM |
