Replacing a worn stick shift / gear lever gaiter - NewBeetle.org Forums
Old 05-01-2008, 09:17 AM
Default Replacing a worn stick shift / gear lever gaiter
I've just ordered a replacement stick shift/ gear lever gaiter as my standard one's started looking a bit tired
I got my new gaiter on e-bay and the bumpf reckons it's fairly straight forward to change but as always, any advice or tips will be very much appreciated.
Old 05-01-2008, 10:55 AM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
Just make sure the shift knob is on there tightly. It's not fun the first time it comes off in your hands.
Old 05-01-2008, 12:57 PM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
Pop out the rectangular surround on the bottom of the boot, and don't break that piece. You'll need it again.
There's staples holding it to the 'leather' which are easier to take out once you have the whole assy out of the car.
Now turn the boot inside out until you see a shiny metal clip that crimps it around the lever. You need to cut that - no way around it. Once you do, pull up on the knob, and the whole thing should come off.
Here's a look at Ladybug
Old 05-01-2008, 03:45 PM
Cheers guys, I now feel loads more confident about doing this. I'll post a picture as soon as its fitted
Old 05-02-2008, 05:01 PM
LadybugEwa's Avatar
PUNCHED BUG
To put in the new assembly, you'll need either a hose clamp or a zip tie to replace the metal clip you've had to cut.
Old 05-07-2008, 01:03 PM
Yipee new gaiter has arrived!
I've removed the old one ( I just cut it out with a pair of scissors ) and am about to fit in the new one. Before I make a mistake is this the clip that needs cutting off from the top of the stick shift....
... if it is, it seems that metal of the clip is quite thick and access fairly restricted. I don't think my dinky snips are gonna be strong enough. What did you use to cut yours?
Old 05-07-2008, 01:57 PM
noR's Avatar
Administrator
Jackson, MS, USA
I used a dremel tool.
That's the metal clip holding your shift knob onto the shaft.
noR | me | Phrog
PHROG
That indeed is the clip and it turns out it's not as hard as it looks. A very easy job, many thanks for all the help.
Old 05-08-2008, 12:55 AM
MiG's Avatar
LkäPORSCHE
excuse me for interupting here but, how or what do you use in replace of that cut clip once the new shifter is on?
LkäPORSCHE
Old 05-08-2008, 12:56 AM
MiG's Avatar
LkäPORSCHE
oops! ....never mind! .... as you were!
Replacing the shift boot-manual Danbike Technical Modifications 2 09-14-2007 09:25 PM
How to install a shift knob/shift boot denisse 2.0 Liter Gas 1 03-16-2007 02:17 PM
Driving in the snow - stick shift? gigoypotpot Questions, Issues, Concerns, or Problems with the New Beetle 7 02-24-2007 01:36 PM
Stick Shift?! niki Miscellaneous Hoo-Ha Archive 58 12-14-2006 09:14 PM
stick shift question vwbeetlewheels Miscellaneous Hoo-Ha Archive 5 09-24-2006 07:04 PM
