That's what mine did when the belt went. The belt might just be missing teeth and so be stuck that way and not actually "broken" A big big deal if it's a 1.8 t, not so much damage if it's a 2.0, but still a big job to do.
TB could only have skipped a couple of teeth, total disintegration is not necessary for it to behave this way.
A friend lended me his auto scanner plus and i pulled the following codes out of his obd II
P0301 points towards 1 cyl missfire P1225 points towards 1 injector grounded P1226 2 injector grounded P1227 3 injector grounded P1451 P1421 P1425 P1472 P0341 This one points towards cam range i do beleive you are right. i am concern about the rest of these codes. thanks ![]() my bugs http://newbeetle.org/forums/photos-new-beetles/ Last edited by newbluebeetle; 05-17-2008 at 11:26 PM.. |
Well guys here is the update, I finnaly worked on my friends car and access the timing belt.
The belt was there but most of the teeth where missing. The cam was 180 degrees from the mark while the crank was just 20 degrees fwd from TDC. I guess the 2.0 engine has enough clearance to avoid massive damage between pistons and valves. Boy did he got lucky. i was feeling gloomy while installing the water pump and belt. i was completely amazed to turn the key and cranked right up. I would like to thank you all for pointing me in the right direction with your information. I should now be able to do my bug with confidence. |
Your welcome Glad it wasn't as bad as mine. The hubby could be heard swearing down the block Now get yours done before something bad happens ![]() |
Well i'm not in the clear yet, apparently he got a code now for p0304 which points towards cyl 4 missfire, i hope i don't have to mess with the timing belt since it only a particular code for only one cyl. however i still want to say thanks to all for your help. now it's a matter for clearing the code and repearing the #4 cyl. And yes, i am getting a water pump and timing belt and will be updating you all of the progress on that one.
Check the coil pack for the cylinder misfire. Does the bug run funny if it is run through a puddle or the motor gets wet? If so, definitely the coil pack, they have a bad habit of cracking and allowing moisture inside. Also, check the plug wire for #4, they break easily.
The following happened after i replaced the timing belt and water pump. Runing the engine, it is a little rough at idle but runs great at speed. The engine light came on and i reset it. then later it came up again P0304. so I replaced the coil and wires. it starts and works good at idle now so i cleared the code. after a while of driving the code came back up again. so the engine light is on and the code is P0304. I am running out of ideas. I think i need to go back to the timing belt and re-check it to make sure i did not miss anything. I the mean time my neighboor is loving his car since he has it back and he is driving the crap out of it. LOL. I am happy just for that. Any way if I try the timing belt and there is nothing there I don't know where else to go. If anybody seen soemthing like this, please help me.
| Engine turns over but will not strt | oblio | 1.9 Liter TDI | 8 | 02-15-2008 10:49 PM |
| Engine Rev on start up | digitalputty | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 04-27-2007 12:50 AM |
| Engine takes a few too many turns to start.... | Shamrockez | 1.9 Liter TDI | 22 | 03-09-2007 06:09 PM |
| Engine turns off | Paradoxx | 2.0 Liter Gas | 4 | 11-23-2006 07:53 PM |
| 2000 NB 1.8T - Engine randomly turns off | mooosenix | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 08-12-2006 07:53 PM |
