Random Stalls - NewBeetle.org Forums
Old 07-15-2008, 01:13 AM
Champlin, MN, USA
Car: 2001 GLX
Question Random Stalls
Hello all,
I have a new intermittent weird stalling problem I can't seem to solve....its happened three times to me so far.
When pulling into parking spots or slowing down for a stop sign the engine stalls. I just recently put in a new timing belt, water pump, MAF, spark plugs, all new fluids....its been maintained.
Any ideas?
Thank you in advance, you have been very helpful in the past!
Matt
2000 New Beetle GLX - 1.8T (APH) - A/T - Black
2001 New Beetle GLX - 1.8T (AWV) - 5 speed - Silver
Old 07-15-2008, 05:18 AM
englishman11's Avatar
Baker City, OR, USA
Car: 1998 New Beetle 2.0, 1968 Beetle, 2011 Ford Fiesta
May be that the fuel filter needs changed.
Old 07-15-2008, 02:01 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Sounds like the timing is off, perhaps a cam and/or crank sensor? Or a coil? Any CEL Codes?
Old 07-15-2008, 03:27 PM
Champlin, MN, USA
Car: 2001 GLX
I changed the fuel filter last month, so I don't think thats it, and it hasn't thrown any codes....I'll go check the timing (its likely to be off because I changed the timing belt myself).
Thank you!
Old 07-15-2008, 04:47 PM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
Thank you!
stalls and dies or stalls and saves itself? check your crank position sensor..there is a resistance test that can be done to see if that is what is bad..i can look it up in bentley if you want
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 01-06-2009, 07:34 PM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
Got any more info on this? Sisters car (2002 1.8T SNAP! automatic) stalls like described. Dealer claims the ignition/coil packs are already replaced. 0_o ...
J'veux pas mourir tout seule.
Old 01-06-2009, 10:38 PM
mrbeetlebrain's Avatar
pixel pusher
Perth, Australia
Car: 2006 MKV GTI
Surely you could pull the codes, must be an error somewhere...
When my car was running rough I had the o2 sensor replaced.
2006 Red MK5 GTI - DSG, Leather, Sunroof, Sat Nav, Xenons || Sold! 2002 Turbo New Beetle
Old 01-06-2009, 10:41 PM
Where is home ....
It has misfiring codes. They were pulled about a year ago. I think cyl 2.
Old 11-07-2009, 12:55 AM
swift801's Avatar
Pittsburgh, PA, USA
Car: 99' Yellow 2.Slo
do you have a hesitation at any other point? i feel like mine will cut at low rpms but quickly regain. mine has also stalled twice today pulling up to stop signs. first time i questioned whether i had clutch in. second time i was like WTF! i threw a code a few weeks ago that said i was running rich. that was tested with a vagcom. where would i start to clean or change parts? i'm only getting 200 miles out of a tank of gas also.
I'm just lookin for bugs....
Old 02-05-2011, 02:18 AM
Beetle1.8turbo's Avatar
Detroit, D-Town, USA
Car: 2001 *1.8 turbo
Did anybody got there NB fix need help mine is doing the same when coming to a stop not every stop but it stall ones a day and no codes , tomorrow am going to get it scan with a vag-scan
Old 02-05-2011, 02:56 PM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Too many directions.....SIMPLY put, its your crank sensor 100%. VERY typical. Once replaced the engine will feel very smooth again. Whenever the Beetle has these symptoms replace the crank position sensor, and no it will not throw codes, odd isn't it? A critical electrical component that never puts a code into the computer. Lots of oops missed that one in the VW rush to produce. It happens in all models right across the range. Replaced mine in a 1.8t 2002 NB and the car pulls and feels like I just drove it off the lot new. Enjoy!! Shouldn't fail again for at least 7 years. Make sure you buy the Bosch one it lasts the longest.
Old 02-05-2011, 03:57 PM
Thumbs up
thank you u know where i can get a bosch one advance auto parts the got the BWD i think they said let me know
Old 02-05-2011, 06:15 PM
Twizzler
This is the Bosch one on eBay right now VW Audi BOSCH Crank Position Sensor Beetle Golf 00-06 - eBay (item 290528256271 end time Feb-27-11 10:26:51 PST) It is compatible with many models of course. I bought mine at a local VW parts guy who sells new and used parts for cheap.
Old 02-05-2011, 09:30 PM
Default hope it fixs my problem
thanks i just got the one from advanceautoparts
Old 02-05-2011, 10:29 PM
is it hard to replace or i can do it myself?
Old 02-09-2011, 01:51 AM
Question info!
i just replace the crank position sensor, do i need to reset the computer or anything like that?
Cyc Misfire, ASR, ESP, stalls Help plz! P944 1.8 Liter Turbo 12 05-27-2009 04:28 PM
Turning right stalls the car? digitalputty Questions, Issues, Concerns, or Problems with the New Beetle 0 10-30-2006 03:21 PM
Several stalls after starting IceDog 2.0 Liter Gas 1 10-17-2006 03:46 PM
Beetle Stalls Every Morning holysweetheart Questions, Issues, Concerns, or Problems with the New Beetle 2 08-10-2006 05:29 AM
