My Vag com is giving me an AIRBAG error code
My airbag light is lite up on my cluster here is the code I get from Vagcom Control Module Part Number: 6Q0 909 605 A Component and/or Version: 06 AIRBAG VW5 0004 Software Coding: 12342 Work Shop Code: WSC 00066 1 Fault Found: 00588 - Airbag Igniter: Driver Side (N95) 33-00 - Resistance too Low Does this mean my driver side airbag is bad? Unplugged? maybe a fuse? does anyone know where the fuse is? The bag has never been deployed and it looks original. So does the passenger side. this beetle has never been in a crash. |
I've had the wire under my passenger seat come loose. The connector is still plugged in, but sometimes after I've folded the seat forward it pulls the wire from the contact, I guess. I turn off the car, remove the key, and feel just about in the center under the seat for the wires plugging into a harness. If you push the wires upward (toward the seat bottom) it should do the trick. You'll probably have to re-VAG it and if the message switches to intermittent clear it and you should be good.
I hope this is the same issue you're having and that it works out!
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings! Mi Bacca es Chewbacca! ![]() ![]() I'm one of those people. Whatever that means. |
| 2003 NB Convertible P-Side Airbag Side Impact Crash Sensor | Jraptor | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 11-29-2007 02:50 AM |
| Airbag light is always on | Dan_Man | 1.9 Liter TDI | 56 | 08-08-2007 08:12 PM |
| Driver Side Seat Airbag | dgrant09 | 2.0 Liter Gas | 9 | 04-17-2006 08:09 PM |
| 2002 drivers side airbag and steering wheel | mark | Market Place Archives | 0 | 03-20-2006 08:52 PM |
| 2005 Steering Wheel and a 2000 Airbag? | SMG | Styling Modifications | 4 | 09-29-2005 06:10 AM |
